SOLVED pods not cleaned up and pod shell not functional
mervincm
I am testing a freshly installed bluefin install. I installed a truechart mkvtoolnox. Default app configuration. start up the app, try to open up the in pod shell, I get this permissions error
WARN[0000] Unable to read /etc/rancher/k3s/k3s.yaml, please start server with --write-kubeconfig-mode to modify kube config permissions
error: error loading config file "/etc/rancher/k3s/k3s.yaml": open /etc/rancher/k3s/k3s.yaml: permission denied
restart the system (universal solver app solution)
for some reason it left behind a pod for this app
mkvtoolnix-5785c6d4d4-tqhgj is still there. I can see it is still there as I can still try to open the shell even though the app is stopped. when you try that with a stopped app, you usually see the error message "No Pools Found"
mervincm
I am glad you added the behaviour to your build thread. That will help future installs I have no doubt. Thanks for the command. I will try it tomorrow. I was mostly interested in sharing that it happened, because it was not behaviour I had seen with prior versions.
