Upgraded to 11.3-U5 (too many problems to list)
Upgraded to 12.1-U1 (resource hog)
Downgraded via clean install of 11.2-U8 iso and restored 11.2 config taken prior to 11.3 upgrade
My jails are not listed under 'Jails' and when I click on 'Plugins->Installed', I get
'Dataset with path not found'
# cat /etc/version
FreeNAS-11.2-U8 (06e1172340)
# iocage --version
Version FreeNAS 11.2-U6
root@freenas:/mnt/SanderNAS/iocage/jails/plex # zfs list
# iocage list
# iocage create -n test ip4_addr="bge0|192.168.0.237/24" -r 11.2-RELEASE
What file is specifying a dataset with a blank path?
Assistance is greatly appreciated.
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 166, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1093, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1037, in _call
return await self._call_worker(name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1058, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 990, in run_in_proc
return await async_run_in_executor(loop, executor, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/utils/asyncio_.py", line 41, in async_run_in_executor
raise result
libzfs.ZFSException: ('Dataset with path not found',)
# cat /etc/version
# iocage --version
NAME USED AVAIL REFER MOUNTPOINT SanderNAS 8.13T 2.35T 8.11T /mnt/SanderNAS SanderNAS/.system 112M 2.35T 192K legacy SanderNAS/.system/configs-76c11d7f8a944b3d8e42fe35420dbaa3 21.9M 2.35T 21.9M legacy SanderNAS/.system/cores 14.0M 1010M 14.0M legacy SanderNAS/.system/rrd-76c11d7f8a944b3d8e42fe35420dbaa3 54.7M 2.35T 54.7M legacy SanderNAS/.system/samba4 1.08M 2.35T 583K legacy SanderNAS/.system/services 192K 2.35T 192K legacy SanderNAS/.system/syslog-76c11d7f8a944b3d8e42fe35420dbaa3 20.1M 2.35T 20.1M legacy SanderNAS/.system/webui 176K 2.35T 176K legacy SanderNAS/iocage 23.0G 2.35T 12.5M /mnt/SanderNAS/iocage SanderNAS/iocage/download 1.06G 2.35T 176K /mnt/SanderNAS/iocage/download SanderNAS/iocage/download/11.2-RELEASE 272M 2.35T 272M /mnt/SanderNAS/iocage/download/11.2-RELEASE SanderNAS/iocage/download/11.3-RELEASE 289M 2.35T 289M /mnt/SanderNAS/iocage/download/11.3-RELEASE SanderNAS/iocage/download/11.4-RELEASE 152M 2.35T 152M /mnt/SanderNAS/iocage/download/11.4-RELEASE SanderNAS/iocage/download/12.1-RELEASE 371M 2.35T 371M /mnt/SanderNAS/iocage/download/12.1-RELEASE SanderNAS/iocage/images 930M 2.35T 930M /mnt/SanderNAS/iocage/images SanderNAS/iocage/jails 15.4G 2.35T 176K /mnt/SanderNAS/iocage/jails SanderNAS/iocage/jails/plex 13.3G 2.35T 1.16M /mnt/SanderNAS/iocage/jails/plex SanderNAS/iocage/jails/plex/root 13.3G 2.35T 12.0G /mnt/SanderNAS/iocage/jails/plex/root SanderNAS/iocage/jails/zoneminder 2.16G 2.35T 807K /mnt/SanderNAS/iocage/jails/zoneminder SanderNAS/iocage/jails/zoneminder/root 2.16G 2.35T 2.16G /mnt/SanderNAS/iocage/jails/zoneminder/root SanderNAS/iocage/log 192K 2.35T 192K /mnt/SanderNAS/iocage/log SanderNAS/iocage/releases 5.59G 2.35T 176K /mnt/SanderNAS/iocage/releases SanderNAS/iocage/releases/11.2-RELEASE 1.50G 2.35T 176K /mnt/SanderNAS/iocage/releases/11.2-RELEASE SanderNAS/iocage/releases/11.2-RELEASE/root 1.50G 2.35T 1.49G /mnt/SanderNAS/iocage/releases/11.2-RELEASE/root SanderNAS/iocage/releases/11.3-RELEASE 1.53G 2.35T 176K /mnt/SanderNAS/iocage/releases/11.3-RELEASE SanderNAS/iocage/releases/11.3-RELEASE/root 1.53G 2.35T 1.53G /mnt/SanderNAS/iocage/releases/11.3-RELEASE/root SanderNAS/iocage/releases/11.4-RELEASE 629M 2.35T 176K /mnt/SanderNAS/iocage/releases/11.4-RELEASE SanderNAS/iocage/releases/11.4-RELEASE/root 629M 2.35T 629M /mnt/SanderNAS/iocage/releases/11.4-RELEASE/root SanderNAS/iocage/releases/12.1-RELEASE 1.95G 2.35T 192K /mnt/SanderNAS/iocage/releases/12.1-RELEASE SanderNAS/iocage/releases/12.1-RELEASE/root 1.94G 2.35T 1.94G /mnt/SanderNAS/iocage/releases/12.1-RELEASE/root SanderNAS/iocage/templates 176K 2.35T 176K /mnt/SanderNAS/iocage/templates freenas-boot 765M 13.3G 64K none freenas-boot/ROOT 765M 13.3G 29K none freenas-boot/ROOT/Initial-Install 1K 13.3G 758M legacy freenas-boot/ROOT/default 765M 13.3G 758M legacy
# iocage list
File "/usr/local/bin/iocage", line 10, in <module>
sys.exit(cli())
File "/usr/local/lib/python3.6/site-packages/click/core.py", line 722, in __call__
return self.main(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/click/core.py", line 697, in main
rv = self.invoke(ctx)
File "/usr/local/lib/python3.6/site-packages/click/core.py", line 1066, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/usr/local/lib/python3.6/site-packages/click/core.py", line 895, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/local/lib/python3.6/site-packages/click/core.py", line 535, in invoke
return callback(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/iocage_cli/list.py", line 81, in cli
dataset_type, header, _long, _sort, plugin=plugins, quick=quick)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1169, in list
quick=quick
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_list.py", line 64, in list_datasets
iocage_lib.ioc_json.IOCJson().json_check_default_config()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_json.py", line 1924, in json_check_default_config
self.json_write(default_props, default_json_location)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_json.py", line 431, in json_write
if template else None
File "libzfs.pyx", line 645, in libzfs.ZFS.get_dataset_by_path
libzfs.ZFSException: Dataset with path not found
