Plugins don't start after rebooting the system
Joshua Parker Ruehlig
I tried...but nothing happened...still I think it's very odd...I hace access to couchpotato and plex from any device without any issue
can your jail ping anything inside your network, how about outside?
mbrunelli87
Hi Joshua
Actually now, after disabling VIMAGE, I think that Transmission Jail pings the IPs outside and inside my network correctly. But still, Transmission interface is not working from my iPad, whereas Couchpotato and Plex work fine :(
I attach the screens
As I said, I don't know why. Can you show a screenshot including the URL of the failed transmission webui from the ipad
mbrunelli87
When I try to connect to 10.0.0.3:9091 (transmission's IP and port) it keeps trying to load the webui and then, after a 30-40 seconds, it says that it could not connect because the server is not responding. Same thing happens with my smartphone and laptop computer (only when using WIFI - if I connect it with the ethernet cable it works)
Jailer
Not strong, but bad
ok I give up. your wireless network is screwy
