Plugin listen on existing interfaces
I downloaded a couple of plugins. My truenas has two interfaces: the first one is connected to my home wifi router (with ip 192.168.1.81), the other one is connected to my personal switch (separate network, without DHCP with ip 192.168.2.2). Now I've tried everything but there's no way I can set the plugin to listen on a certain interface rather than another (or both). How can I set my plugins to listen on both 192.168.1.81 and 192.168.2.2 interfaces?
I've tried everything but it doesn't seem to work. The qbittorrent plugin, for example, gives me the "VNET required" error. The problem is that I have to disable the vnet to be able to insert a second interface. How is it possible that truenas is so complicated to insert a second interface!?
