I currently upgraded from 8.3 to 9.2.1.2 and cant get any plugins to uninstall nor can I get any new ones to install either.. Any kind of help would be greatly appreciated.. Here is the errors I am seeing.
Installing error - Basically it gets the jail created and installed but fails at installing the plugin itself see below.
Mar 2 16:10:33 Media Server kernel: epair0a: promiscuous mode enabled
Mar 2 16:10:33 Media Server rtsold[1539]: interface epair0b removed
Mar 2 16:10:53 Media Server manage.py: [middleware.exceptions:38] [MiddlewareError: The command /usr/sbin/jexec 1 /usr/local/sbin/pbi_add -f --no-checksig /.plugins/owncloud-6.0.1-amd64.pbi failed: ""]
Uninstalling older 8.3 plugin
Mar 2 16:15:29 Media Server manage.py: [middleware.exceptions:38] [MiddlewareError: The plugins jail is not running, start it before proceeding]
Mar 2 16:15:31 Media Server manage.py: [plugins.utils:92] Couldn't retrieve http://192.168.1.xxx/plugins/firefly/2/_s/status: No JSON object could be decoded
Mar 2 16:15:32 Media Server manage.py: [plugins.utils:92] Couldn't retrieve http://192.168.1.xxx/plugins/minidlna/1/_s/status: No JSON object could be decoded
Any help with these would be appreciated. I am at a loss..
Thanks
Troy
Thanks
Troy
