Hello, All
I'm having troubles with disks dropping out under ZFS scrubs.
Running FreeNAS-8.0.4-RELEASE-p1-x64 (11059)
AMD Phenom(tm) II X2 560 Processor
16 GB ECC RAM
ATI IXP700 AHCI SATA controller
Samsung HD204UI drives
The problem is in my disk controller. Exactly as described here:
http://forums.freebsd.org/showthread.php?t=24189
The question is how to force ata(4) driver for the controller?
Tried setting mobo to IDE mode. Also tried ahci_load="NO" in loader.conf
No luck. Still loads the controller as achi
Thanks a lot!
16 GB ECC RAM
Thanks a lot!
