dirtyfreebooter
- Oct 3, 2020
every time i try and upgrade plex i get this:
i have no clue what that means. anyone have any idea? thanks
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 426, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 461, in __run_body rv = await self.method(*([self] + args)) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1186, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1318, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/chart_release.py", line 553, in do_update await self.middleware.call('chart.release.helm_action', chart_release, chart_path, config, 'update') File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1386, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1346, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1249, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/helm.py", line 44, in helm_action raise CallError(f'Failed to {tn_action} chart release: {stderr.decode()}') middlewared.service_exception.CallError: [EFAULT] Failed to update chart release: Error: UPGRADE FAILED: cannot patch "plex" with kind Deployment: Deployment.apps "plex" is invalid: spec.template.spec.containers[0].resources.limits: Required value: Limit must be set for non overcommitable resources
