Plex service stopping inside jail
itractus
I've added the follwoing line to crontab. Now let's catch this error in action!
5 * * * *  ps awwux >>/media/Books/ps.txt
I will change this to */5 as per commendation
Patrick M. Hausen
Is that first value */5? If it is just 5, you will get a list every hour, only.
Please post text via copy&paste included in "CODE" tags instead of screenshots.
itractus
So after a night of running the txt file shows up empty. I realised I did the cron from inside the jail and just now changed it to the host. Hopefully now I can actually capture the error.
I'm posting here just to keep people in the loop and showing people who stumble here how I went about and tracked down the issue.
Patrick M. Hausen
That should work inside the jail just as well as long as /media/Books is a writeable path inside the jail.
BTW: you can check if anything ends up in the text file after five minutes, already. No need to wait an entire night.
Possibly you are not running cron at all in the jail?
When doing it outside the jail, use the UI, don't edit any crontab on the command line.
itractus
I made sure the mountpoint was writable by creating the ps.txt file using touch and setting permissions to 777 just in case.
This might be the case, though I now bypass this by using the host to do the cron
Ok, I removed the manual entry and remade it using the GUI:
Jailer
Not strong, but bad
Have you checked the Plex logs to see what shows up there at the time of the crash?
itractus
It seems like this also does not produce
Great question and I'm sad to say I forgot to mention this but I made a thread on the plex forums explaining this behavior and the logs are attached. They show nothing out of the ordinary at the time of the crash.
Patrick M. Hausen
Patrick M. Hausen
Ah - so the UI probably just slaps a >/dev/null on the end of the line or similar.
itractus
So after a couple of days, I stopped the task. Having collected enough data I think.
In attachement the file. I'll be looking through it finding out what is happening
  • ps.txt
