*bump*
I am having similar issues starting ombi v 2.2.1 with mono 5.10.1.57
Since afaik no1 has gotten ombi v3 working in a freenas icoage jail as of yet?
any pointers what the cause might be or where to look for culprits?
error msg dump:
Starting Up! Please wait, this can usually take a few seconds.
Version: 2.2.1678
Location of the database: /usr/local/share/ombi/Ombi.sqlite
Your operating system's sysconf (3) function doesn't correctly report physical memory size!
[ERROR] FATAL UNHANDLED EXCEPTION: NLog.NLogConfigurationException: Error when setting property 'Format' on Layout Renderer: ${exception} ---> System.ArgumentException: Object of type 'System.ReadOnlySpan`1[System.Char]' cannot be converted to type 'System.String'.
  at System.RuntimeType.CheckValue (System.Object value, System.Reflection.Binder binder, System.Globalization.CultureInfo culture, System.Reflection.BindingFlags invokeAttr) [0x00071] in <0e06830de9a44394a7e366951eabca52>:0
  at System.Reflection.MonoMethod.ConvertValues (System.Reflection.Binder binder, System.Object[] args, System.Reflection.ParameterInfo[] pinfo, System.Globalization.CultureInfo culture, System.Reflection.BindingFlags invokeAttr) [0x00069] in <0e06830de9a44394a7e366951eabca52>:0
  at System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x00011] in <0e06830de9a44394a7e366951eabca52>:0
  at System.Reflection.MonoProperty.SetValue (System.Object obj, System.Object value, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] index, System.Globalization.CultureInfo culture) [0x0005d] in <0e06830de9a44394a7e366951eabca52>:0
  at System.Reflection.PropertyInfo.SetValue (System.Object obj, System.Object value, System.Object[] index) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0
  at NLog.Internal.PropertyHelper.SetPropertyFromString (System.Object obj, System.String propertyName, System.String value, NLog.Config.ConfigurationItemFactory configurationItemFactory) [0x00108] in <3ba0cff67b4d49d79d53f79e839f8ad9>:0
   --- End of inner exception stack trace ---
  at NLog.Internal.PropertyHelper.SetPropertyFromString (System.Object obj, System.String propertyName, System.String value, NLog.Config.ConfigurationItemFactory configurationItemFactory) [0x001bc] in <3ba0cff67b4d49d79d53f79e839f8ad9>:0
  at NLog.Layouts.LayoutParser.ParseLayoutRenderer (NLog.Config.ConfigurationItemFactory configurationItemFactory, NLog.Internal.SimpleStringReader sr) [0x001a3] in <3ba0cff67b4d49d79d53f79e839f8ad9>:0
  at NLog.Layouts.LayoutParser.CompileLayout (NLog.Config.ConfigurationItemFactory configurationItemFactory, NLog.Internal.SimpleStringReader sr, System.Boolean isNested, System.String& text) [0x0009a] in <3ba0cff67b4d49d79d53f79e839f8ad9>:0
  at NLog.Layouts.SimpleLayout.set_Text (System.String value) [0x00013] in <3ba0cff67b4d49d79d53f79e839f8ad9>:0
  at NLog.Layouts.SimpleLayout..ctor (System.String txt, NLog.Config.ConfigurationItemFactory configurationItemFactory) [0x0000d] in <3ba0cff67b4d49d79d53f79e839f8ad9>:0
  at NLog.Layouts.Layout.FromString (System.String layoutText, NLog.Config.ConfigurationItemFactory configurationItemFactory) [0x00000] in <3ba0cff67b4d49d79d53f79e839f8ad9>:0
  at NLog.Layouts.Layout.FromString (System.String layoutText) [0x00006] in <3ba0cff67b4d49d79d53f79e839f8ad9>:0
  at NLog.Layouts.Layout.op_Implicit (System.String text) [0x00000] in <3ba0cff67b4d49d79d53f79e839f8ad9>:0
  at Ombi.Helpers.LoggingHelper.ConfigureLogging (System.String connectionString) [0x000f1] in <dd625652ceaa4132973cc40b9d7e32b8>:0
  at Ombi.UI.Program.ConfigureTargets (System.String connectionString) [0x00000] in <d3edc51f5e544d5c9ddfe4ca6f7ce873>:0
  at Ombi.UI.Program.Main (System.String[] args) [0x00154] in <d3edc51f5e544d5c9ddfe4ca6f7ce873>:0
