Here are the results:
smartctl -q noserial -a /dev/ada0
Model Family:     Western Digital Caviar Green (Adv. Format)
Device Model:     WDC WD20EARX-00PASB0
Firmware Version: 51.0AB51
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
ATA Version is:   8
ATA Standard is:  Exact ATA specification draft version not indicated
Local Time is:    Sat Mar 16 08:19:41 2013 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (38580) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 372) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x3035) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   215   173   021    Pre-fail  Always       -       4225
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       435
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   094   094   000    Old_age   Always       -       4689
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       433
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       93
193 Load_Cycle_Count        0x0032   199   199   000    Old_age   Always       -       3958
194 Temperature_Celsius     0x0022   120   115   000    Old_age   Always       -       30
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%      4689         -
smartctl -q noserial -a /dev/ada1
ATA Version is:   8
Local Time is:    Sat Mar 16 08:21:01 2013 PDT
                                        been run.
data collection:                (36480) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 352) minutes.
  3 Spin_Up_Time            0x0027   212   166   021    Pre-fail  Always       -       4358
193 Load_Cycle_Count        0x0032   199   199   000    Old_age   Always       -       4074
194 Temperature_Celsius     0x0022   121   117   000    Old_age   Always       -       29
No Errors Logged
smartctl -q noserial -a /dev/ada2
Device Model:     WDC WD20EARX-008FB0
ATA Version is:   8
Local Time is:    Sat Mar 16 08:21:25 2013 PDT
                                        been run.
data collection:                (33960) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 365) minutes.
SCT capabilities:              (0x30b5) SCT Status supported.
  3 Spin_Up_Time            0x0027   226   186   021    Pre-fail  Always       -       3700
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       107
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       836
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       107
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       21
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       140
194 Temperature_Celsius     0x0022   122   118   000    Old_age   Always       -       28
No Errors Logged
# 1  Short offline       Completed without error       00%       836         -
smartctl -q noserial -a /dev/ada3
ATA Version is:   8
Local Time is:    Sat Mar 16 08:21:47 2013 PDT
                                        been run.
data collection:                (37680) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 363) minutes.
  3 Spin_Up_Time            0x0027   215   172   021    Pre-fail  Always       -       4241
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       436
  9 Power_On_Hours          0x0032   094   094   000    Old_age   Always       -       4690
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       434
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       94
193 Load_Cycle_Count        0x0032   199   199   000    Old_age   Always       -       4044
194 Temperature_Celsius     0x0022   122   116   000    Old_age   Always       -       28
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       16
No Errors Logged
smartctl -q noserial -a /dev/ada4
ATA Version is:   8
Local Time is:    Sat Mar 16 08:22:06 2013 PDT
                                        been run.
data collection:                (36780) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 355) minutes.
  3 Spin_Up_Time            0x0027   208   164   021    Pre-fail  Always       -       4600
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       440
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       438
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       98
193 Load_Cycle_Count        0x0032   199   199   000    Old_age   Always       -       4105
194 Temperature_Celsius     0x0022   121   115   000    Old_age   Always       -       29
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       3
No Errors Logged
smartctl -q noserial -a /dev/ada5
ATA Version is:   8
Local Time is:    Sat Mar 16 08:22:35 2013 PDT
                                        been run.
data collection:                (38880) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 375) minutes.
  3 Spin_Up_Time            0x0027   211   166   021    Pre-fail  Always       -       4441
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       95
193 Load_Cycle_Count        0x0032   199   199   000    Old_age   Always       -       4040
No Errors Logged
All without errors...
