Hi there,
I'm trying to install Piwigo 13.8 on TrueNAS Scale 22.12 (Bluefin) on an old server I've had for about 10 years (CPU x5660, 16GB DDR3 ECC). Initially, I had FreeNAS installed, but I recently upgraded to Scale to take advantage of easier application installation and better hardware utilization without having to create VMs. I thought the official TrueNAS catalogs and TrueCharts would make installations as simple as a click. However, I've found it to be just as complex as Core when installing Nextcloud (with TrueCharts, I had to install pgAdmin, CloudNative-PG, Prometheus, which took me several days to figure out until I received a response on the TrueCharts Discord).
Now I'm attempting to install Piwigo, which I also thought would be straightforward using the catalog or Docker. However, it's not available in the catalog, only in the TrueCharts Incubator catalog, and it's version 11.5. I wanted to install the latest stable version, which is 13.8. I've tried everything, but I couldn't even get version 11.5 to work because I couldn't get Mariadb to function properly. Can someone please help me or guide me on what I should do or know to install Piwigo? Thank you very much in advance.
Best regards,
Best regards,
