I've made my complete own development plugin repository for JailMan, so I think i'm you... well... "man" in this case...I checked the TrueNAS documentation but only found one item with the search function which was applicable. Even if there is no formal method for community effort in updating plugins, I'm sure that if you succeeded with getting any plugin to be functional, the information and testing involved would be appreciated. As for how this might be submitted, perhaps a link to a github or similar vcs site might make it easy, but surely TrueNAS devs like @Kris Moore would know for sure.
I've looked into "MotionEye" for you.
It looks like the plugin was created in september and just isn't maintained, so they also didn't submit verification it works on the latest versions (by updating the release in the json).
GitHub - cilix-lab/iocage-plugin-motioneye
Contribute to cilix-lab/iocage-plugin-motioneye development by creating an account on GitHub.github.com
I've looked at the plugin code and I don't think there is anything in the plugin code that is inherently incompatible with 12, 12.1 or 12.2.
So you might be in luck just updating the release :D
You should be able to force an install with:
iocage fetch -g "https://github.com/ix-plugin-hub/iocage-plugin-index" -P "motioneye" -n "motioneye" -r "12.1-RELEASE " dhcp="on" vnet="on" allow_raw_sockets="1" boot="on"
If that doesn't work you can also manually install a plugin straight from the json by force.
root@thing:/ # iocage fetch -g "https://github.com/ix-plugin-hub/iocage-plugin-index" -P "motioneye" -n "testeye" -r "12.2-RELEASE " dhcp="on" vnet="on" allow_raw_sockets="1" boot="on"
Cloning git repository
Plugin: motioneye
Official Plugin: False
Using RELEASE: 11.3-RELEASE
Using Branch: 12.2-RELEASE
Post-install Artifact: https://github.com/cilix-lab/iocage-plugin-motioneye.git
These pkgs will be installed:
- python27
- py27-pip
- motion
- ffmpeg
- v4l-utils
- jpeg-turbo
- curl
Testing Host DNS response to pkg.FreeBSD.org
Testing testeye's SRV response to pkg.FreeBSD.org
Testing testeye's DNSSEC response to pkg.FreeBSD.org
Installing plugin packages:
- python27...
- py27-pip...
- motion...
- ffmpeg...
- v4l-utils...
- jpeg-turbo...
- curl...
Fetching artifact...
Branch 12.2-RELEASE does not exist at https://github.com/cilix-lab/iocage-plugin-motioneye.git!
Using "master" branch for plugin, this may not work with your RELEASE
Running post_install.sh
DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support pip 21.0 will remove support for this functionality.
Collecting motioneye
Downloading motioneye-0.42.1.tar.gz (758 kB)
Collecting tornado<6,>=3.1
Downloading tornado-5.1.1.tar.gz (516 kB)
Collecting jinja2
Downloading Jinja2-2.11.2-py2.py3-none-any.whl (125 kB)
Collecting pillow
Downloading Pillow-6.2.2.tar.gz (37.8 MB)
Collecting pycurl
Downloading pycurl-7.43.0.5.tar.gz (216 kB)
Collecting futures
Downloading futures-3.3.0-py2-none-any.whl (16 kB)
Collecting singledispatch
Downloading singledispatch-3.4.0.3-py2.py3-none-any.whl (12 kB)
Collecting backports_abc>=0.4
Downloading backports_abc-0.5-py2.py3-none-any.whl (5.2 kB)
Collecting MarkupSafe>=0.23
Downloading MarkupSafe-1.1.1.tar.gz (19 kB)
Collecting six
Downloading six-1.15.0-py2.py3-none-any.whl (10 kB)
Using legacy 'setup.py install' for motioneye, since package 'wheel' is not installed.
Using legacy 'setup.py install' for tornado, since package 'wheel' is not installed.
Using legacy 'setup.py install' for pillow, since package 'wheel' is not installed.
Using legacy 'setup.py install' for pycurl, since package 'wheel' is not installed.
Using legacy 'setup.py install' for MarkupSafe, since package 'wheel' is not installed.
Installing collected packages: futures, six, singledispatch, backports-abc, tornado, MarkupSafe, jinja2, pillow, pycurl, motioneye
Running setup.py install for tornado: started
Running setup.py install for tornado: finished with status 'done'
Running setup.py install for MarkupSafe: started
Running setup.py install for MarkupSafe: finished with status 'done'
Running setup.py install for pillow: started
Running setup.py install for pillow: finished with status 'done'
Running setup.py install for pycurl: started
Running setup.py install for pycurl: finished with status 'done'
Running setup.py install for motioneye: started
Running setup.py install for motioneye: finished with status 'done'
Successfully installed MarkupSafe-1.1.1 backports-abc-0.5 futures-3.3.0 jinja2-2.11.2 motioneye-0.42.1 pillow-6.2.2 pycurl-7.43.0.5 singledispatch-3.4.0.3 six-1.15.0 tornado-5.1.1
motioneye_enable: -> YES
Starting motioneye.
Admin Portal:
http://192.168.1.215:8765
Doc URL:
https://github.com/cilix-lab/iocage-plugin-index
Whoops, I made a mistake... There is a space behind "12.2-RELEASE" in my command example, so it defaulted to 11.3
root@thing:/ # iocage fetch -g "https://github.com/ix-plugin-hub/iocage-plugin-index" -P "motioneye" -n "testeye" -r "12.2-RELEASE" dhcp="on" vnet="on" allow_raw_sockets="1" boot="on"
Plugin: motioneye
- python27
- py27-pip
- motion
- ffmpeg
- v4l-utils
- jpeg-turbo
- curl
- python27...
- py27-pip...
- motion...
- ffmpeg...
- v4l-utils...
- jpeg-turbo...
- curl...
Collecting jinja2
Collecting pillow
Collecting pycurl
Collecting futures
Collecting six
Starting motioneye.
Admin Portal:
Doc URL:
root@thing:/ # http://192.168.1.215:8765
http://192.168.1.215:8765: Command not found.
root@thing:/ #
root@thing:/ # iocage console testeye
FreeBSD 12.2-RELEASE-p2 663e6b09467(HEAD) TRUENAS
Welcome to FreeBSD!
Release Notes, Errata: https://www.FreeBSD.org/releases/
Security Advisories: https://www.FreeBSD.org/security/
FreeBSD Handbook: https://www.FreeBSD.org/handbook/
FreeBSD FAQ: https://www.FreeBSD.org/faq/
Questions List: https://lists.FreeBSD.org/mailman/listinfo/freebsd-questions/
FreeBSD Forums: https://forums.FreeBSD.org/
Documents installed with the system are in the /usr/local/share/doc/freebsd/
directory, or can be installed later with: pkg install en-freebsd-doc
For other languages, replace "en" with a language code like de or fr.
Show the version of FreeBSD installed: freebsd-version ; uname -a
Please include that output and any error messages when posting questions.
Introduction to manual pages: man man
FreeBSD directory layout: man hier
Edit /etc/motd to change this login announcement.
root@testeye:~ # freebsd-version
11.3-RELEASE-p14
root@thing:/ # iocage fetch -P motioneye122.json -n testeye3 dhcp="on" vnet="on" allow_raw_sockets="1" boot="on"
Plugin: motioneye
Using RELEASE: 12.2-RELEASE
- python27
- py27-pip
- motion
- ffmpeg
- v4l-utils
- jpeg-turbo
- curl
Testing testeye3's SRV response to pkg.FreeBSD.org
Testing testeye3's DNSSEC response to pkg.FreeBSD.org
- python27...
- py27-pip...
- motion...
- ffmpeg...
- v4l-utils...
- jpeg-turbo...
- curl...
Collecting jinja2
Collecting pillow
Collecting pycurl
Collecting futures
Collecting six
Starting motioneye.
Admin Portal:
http://192.168.1.218:8765
Doc URL:
Awesome!
Be sure to file a pullrequest for both master and all release branches (and be sure to adapt the release version to every release branch)
You can pretty safely add it to 12.1 and 12.0 if you tested 11.3 and 12.2.Well, I can do that for the releases I test but I don't have every version of TrueNAS available to me to test with.
I verified the code for you before... There is nothing special in it that got destroyed in those versions :)
