"Updating local repository catalogue...
pkg: file:///usr/ports/packages/meta.txz: No such file or directory
repository local has no meta file, using default settings
pkg: file:///usr/ports/packages/packagesite.txz: No such file or directory
Unable to update repository local
All repositories are up-to-date.
pkg: Repository local cannot be opened. 'pkg update' required
pkg: No packages available to install matching 'php56' have been found in the re
positories"
What version of FreeNAS are you using and if you are on a 9.10 version did you upgrade from 9.3. That is what it sounds like so may want to do the upgrade to 11 and create a new jail. Otherwise there may be a connection problem that is preventing you from downloading.
My problem was because i didn't perform the command in the jail shell
"root@nextcloud_1:/ # pkg install php56
Updating FreeBSD repository catalogue...
FreeBSD repository is up to date.
All repositories are up to date.
Checking integrity... done (0 conflicting)
The most recent version of packages are already installed
seems that it did the update just fine
i then restarted the jail
but nextcloud is still telling me that i am on php5.5
pkg delete php55 followed by service php-fpm restart.
Do note that if you have all of the php55 dependencies installed it will delete all of them too. You'll likely have to re install all of them to match the php version you are using.
Also is this a plugin or manual install in a standard jail?
root@nextcloud_1:/ # pkg delete php55
No packages matched for pattern 'php55'
Package(s) not found!
I am using nextcloud plugin
i did the first command to download and install php5.6
but the two commands that you said to try didnt do anything
At this point i already completely deleted nextcloud and started over
when i reinstalled nextcloud it still only gave me nextcloud 10
Ok you can't update the packages that the nextcloud plugin was built with. You'll have to wait until the nextcloud plugin maintainer updates the plugin which isn't likely to happen since the plugins are going to change in FreeNAS 11.1.
You'd be much better served with a manual install in a standard jail that you can keep up to date yourself.
Wait for the next Nextcloud plugin update or do a manual install in a standard jail. pkg install nexcloud will work or you can follow the guide in the forums. It's written for Owncloud but everything is the same. Just substitute Nexcloud for Owncloud in the instructions.
