 - Jul 3, 2015
I'm running FreeNAS-9.10-STABLE-201604181743 on two servers although I've also seen this issue on 9.3.1 recently too.
When replicating from one box to the other all is fine but if you create a new dataset on primary it replicates fine to secondary but when you inspect the permissions they are wrong so for a recent example a dataset with windows permissions on the primary had unix permissions on the secondary and root had been set as the owner on the secondary when another user was owner on the primary. Also any ACLs I'd created were shot. Both boxes have the same users with the same UIDs so I know its not that. If I reboot secondary box when it comes back everything looks great again so it appears the information is transferring fine but just getting confused when landing.
Like I said:
1. This only happens on datasets created after the initial replication has been setup
2. After a reboot of secondary box everything is fine
3. I'm running the latest version of 9.10 but have seen this issue on two 9.3.1 boxes also
4. I've only noticed this issue since datasets replicated were marked as readyonly which I think started in 9.3.1 about 6 months ago
