Hi all,
I have a FreeNAS-9.10.2-U4 machine that has been running for a couple years now. This morning I found it to be responsive to ping, but otherwise unreachable via WebGUI, SMB, or SSH. After hooking it up to a monitor, I found this:
Am I correct in thinking that the USB drive is corrupt, has failed, or is otherwise unwritable? Can I clone the USB (using dd) and then swap it out without a problem? Or should I download a fresh installation and reload the configuration from backup? Or, does this error mean something else?
Any advice is much appreciated.
Thanks!
Thanks!
