After update to TrueNAS 12.0, I am experiencing some problems pointed in subject.
Ido not what is the origin of the problem because nothing seem to be wrong. When I reboot system it works fine for two days and after I get then same issue.
Can anyone give me some help?
Thanks
The alert I get is the following:
"New alerts:
* Pool RAIDZ2 state is DEGRADED: One or more devices has been removed by the administrator. Sufficient replicas exist for the pool to continue functioning in a degraded state.
The following devices are not healthy:
Disk 14287883434686960263 is REMOVED"
Furthermore the output of "smartctl -x /dev/ada2", which is the REMOVED disk is:
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p6 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WCC4N2ZE667C
LU WWN Device Id: 5 0014ee 2118ed184
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon May 31 08:39:30 2021 IST
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
been run.
data collection: (43260) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 434) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0
3 Spin_Up_Time POS--K 210 179 021 - 4475
4 Start_Stop_Count -O--CK 100 100 000 - 25
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 092 092 000 - 6027
10 Spin_Retry_Count -O--CK 100 253 000 - 0
11 Calibration_Retry_Count -O--CK 100 253 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 25
192 Power-Off_Retract_Count -O--CK 200 200 000 - 15
193 Load_Cycle_Count -O--CK 200 200 000 - 71
194 Temperature_Celsius -O---K 111 101 000 - 39
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 2
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x0c GPL R/O 2048 Pending Defects log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb7 GPL,SL VS 1 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 4
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Error 4 [3] occurred at disk power-on lifetime: 5885 hours (245 days + 5 hours)
When the command that caused the error occurred, the device was doing SMART Offline or Self-test.
ER -- ST COUNT LBA_48 LH LM LL DV DC
10 -- 51 00 30 00 00 fd 25 3f 70 40 00 Error: IDNF 48 sectors at LBA = 0xfd253f70 = 4247076720
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
35 00 00 00 30 00 00 fd 25 3f 70 40 00 1d+12:35:08.901 WRITE DMA EXT
35 00 00 00 08 00 00 e0 52 7f 58 40 00 1d+12:35:08.884 WRITE DMA EXT
35 00 00 00 30 00 00 dd 2c 75 f0 40 00 1d+12:35:08.839 WRITE DMA EXT
35 00 00 00 28 00 00 d6 e1 80 88 40 00 1d+12:35:08.803 WRITE DMA EXT
35 00 00 00 38 00 00 d0 5f 51 60 40 00 1d+12:35:08.772 WRITE DMA EXT
Error 3 [2] occurred at disk power-on lifetime: 5885 hours (245 days + 5 hours)
10 -- 51 00 08 00 00 fd 25 3f 60 40 00 Error: IDNF 8 sectors at LBA = 0xfd253f60 = 4247076704
35 00 00 00 08 00 00 fd 25 3f 60 40 00 1d+12:34:56.632 WRITE DMA EXT
35 00 00 00 08 00 00 fd 25 3f 60 40 00 1d+12:34:49.636 WRITE DMA EXT
35 00 00 00 08 00 00 fd 25 3f 60 40 00 1d+12:34:42.639 WRITE DMA EXT
35 00 00 00 08 00 00 e0 52 7f 50 40 00 1d+12:34:42.621 WRITE DMA EXT
35 00 00 00 08 00 00 dd 2c 75 e8 40 00 1d+12:34:42.604 WRITE DMA EXT
Error 2 [1] occurred at disk power-on lifetime: 5885 hours (245 days + 5 hours)
35 00 00 00 08 00 00 d6 e1 80 80 40 00 1d+12:34:42.573 WRITE DMA EXT
Error 1 [0] occurred at disk power-on lifetime: 5885 hours (245 days + 5 hours)
35 00 00 00 08 00 00 d0 5f 51 50 40 00 1d+12:34:42.546 WRITE DMA EXT
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Short offline Completed without error 00% 5996 -
# 2 Extended offline Completed without error 00% 5889 -
# 3 Short offline Completed without error 00% 5673 -
# 4 Short offline Completed without error 00% 5506 -
# 5 Short offline Completed without error 00% 5338 -
# 6 Extended offline Completed without error 00% 5205 -
# 7 Short offline Completed without error 00% 5170 -
# 8 Short offline Completed without error 00% 5002 -
# 9 Short offline Completed without error 00% 4834 -
#10 Short offline Completed without error 00% 4666 -
#11 Extended offline Completed without error 00% 4534 -
#12 Short offline Completed without error 00% 4499 -
#13 Short offline Completed without error 00% 4331 -
#14 Short offline Completed without error 00% 4279 -
#15 Short offline Completed without error 00% 4111 -
#16 Extended offline Completed without error 00% 3954 -
#17 Short offline Completed without error 00% 3943 -
#18 Short offline Completed without error 00% 3820 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
Device State: Active (0)
Current Temperature: 39 Celsius
Power Cycle Min/Max Temperature: 37/39 Celsius
Lifetime Min/Max Temperature: 2/49 Celsius
Under/Over Temperature Limit Count: 0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (66)
Index Estimated Time Temperature Celsius
67 2021-05-31 00:42 39 ********************
... ..(476 skipped). .. ********************
66 2021-05-31 08:39 39 ********************
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 2) ==
0x01 0x008 4 25 --- Lifetime Power-On Resets
0x01 0x010 4 6027 --- Power-on Hours
0x01 0x018 6 6449146690 --- Logical Sectors Written
0x01 0x020 6 196831718 --- Number of Write Commands
0x01 0x028 6 15389718894 --- Logical Sectors Read
0x01 0x030 6 64064411 --- Number of Read Commands
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 5855 --- Spindle Motor Power-on Hours
0x03 0x010 4 5851 --- Head Flying Hours
0x03 0x018 4 87 --- Head Load Events
0x03 0x020 4 0 --- Number of Reallocated Logical Sectors
0x03 0x028 4 69 --- Read Recovery Attempts
0x03 0x030 4 0 --- Number of Mechanical Start Failures
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 4 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 131074 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 38 --- Current Temperature
0x05 0x010 1 37 --- Average Short Term Temperature
0x05 0x018 1 40 --- Average Long Term Temperature
0x05 0x020 1 48 --- Highest Temperature
0x05 0x028 1 28 --- Lowest Temperature
0x05 0x030 1 45 --- Highest Average Short Term Temperature
0x05 0x038 1 37 --- Lowest Average Short Term Temperature
0x05 0x040 1 43 --- Highest Average Long Term Temperature
0x05 0x048 1 40 --- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 60 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 0 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 88 --- Number of Hardware Resets
0x06 0x010 4 410 --- Number of ASR Events
0x06 0x018 4 0 --- Number of Interface CRC Errors
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 10 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 11 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 79441 Vendor specific
Thanks
"New alerts:
was never started.
been run.
command.
power-saving mode.
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
ER = Error register
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Vendor specific:
||__ D supports DSN
No Defects Logged
