mlinton
- Jun 20, 2013
Use Case: Photography Backup / Archive (with the need to access the archives somewhat frequently). Currently, archives are stored on individual external hard drives in a closet. The user would like to have onsite, offsite and cloud backups. This system would be sitting at the primary office and use crash plan to copy data to the sister system offsite and to the cloud. Bandwidth issues have been addressed.
Main System / Sister System Build:
Case: Fractal Node 304 - http://www.newegg.com/Product/Product.aspx?Item=N82E16811352027
HDD: WD Red 4TB, x4, RAIDZ - http://www.newegg.com/Product/Product.aspx?Item=N82E16822236599
PSU: SeaSonic, 360W, 80 Gold - http://www.newegg.com/Product/Product.aspx?Item=N82E16817151117
MD/CPU: ASRock C2550D4I- http://www.newegg.com/Product/Product.aspx?Item=N82E16813157419
BOOT: ADATA S102 Pro 16GB - http://www.newegg.com/Product/Product.aspx?Item=N82E16820211572
RAM: Crucial 16GB (2 x 8GB) 240-Pin DDR3 SDRAM ECC Unbuffered DDR3 1600 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820148770
BOOT Adapter: USB A Female to USB Motherboard 4 Pin - http://www.newegg.com/Product/Product.aspx?Item=N82E16812200294
This is my 3rd FreeNAS build, but my first build for another person. I would like to have it peer reviewed for any inaccuracies.
I will be using the Intel controller SATA ports. Using RAIDZ (NOT RAIDZ2) because the data will by copied to multiple sites and the cost/benefit didn't weigh out for Z2.
Thank you for your review.
Mark
Mark
