One drive of 4 substantially slower than the others during badblocks destructive test.
Mongo_Loyd
Hello everyone,
I am doing a burn-in of 4 HGST with the badblocks destructive test.
Currently they are on the third destructive write test 0xff
da0 is at 93%
da1 is at 95%
da2 is at 76%
da3 is at 90%
da2 is substantially slower, but shows no errors at the moment. Should I RMA this drive or is it ok to use if it completes the test without errors?
I'll be doing the long smart test afterwards and then reviewing the results.
Any suggestions? Is this common.
They are all WD Ultrastar DC H550 18tb SAS drives.
Wait for that first... many factors can drive which disks are favored in cases where the controller is under heavy load (which is likely the case if you're writing to 4 disks at maximum speed simultaneously).
Check dmesg to ensure you're not getting checksum errors (suspect cabling if you are).
Mongo_Loyd
Thanks sretalla,
Here is the output. I don't see any checksum errors. I removed a couple hundred lines to get past the 30k character limit for a post.
I can't ssh into the machine or access the web gui. This is from an open ssh session I had.
root@t610[/mnt/usbpool]# dmesg
sonewconn: pcb 0xfffff800a8b8a600: Listen queue overflow: 193 already in queue awaiting acceptance (1 occurrences)
sonewconn: pcb 0xfffff800a8b8a600: Listen queue overflow: 193 already in queue awaiting acceptance (2 occurrences)
Those are all about network connection driver queues, not disks, so nothing there indicating CAM status errors.
You might want to look into those though depending on your use of the NAS.
