Radu
 - Mar 7, 2014
I have the old stick mounted in a new freenas instalation:
[root@fns] /mnt/test# zpool status oldboot
pool: oldboot
state: DEGRADED
status: The pool is formatted using a legacy on-disk format. The pool can
still be used, but some features are unavailable.
action: Upgrade the pool using 'zpool upgrade'. Once this is done, the
pool will no longer be accessible on software that does not support feature
flags.
scan: scrub repaired 0 in 0h5m with 0 errors on Sat Oct 17 04:09:04 2015
NAME STATE READ WRITE CKSUM
oldboot DEGRADED 0 0 0
mirror-0 DEGRADED 0 0 0
replacing-0 UNAVAIL 0 0 0
6084986419970871387 UNAVAIL 0 0 0 was /dev/da17p2/old
16363155523381452286 FAULTED 0 0 0 was /dev/da17p2
gptid/c71114c8-9ffd-11e4-b19c-002590f0d4ba ONLINE 0 0 0
errors: No known data errors
[root@fns] /mnt/test# zpool list
NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
buffer 1.36T 540G 852G - 36% 38% 1.00x ONLINE /mnt
freenas-boot 7.38G 521M 6.87G - - 6% 1.00x ONLINE -
oldboot 7.19G 4.89G 2.30G - - 67% 1.00x DEGRADED /mnt/test
sys_jail 53.5G 15.8G 37.7G - 31% 29% 1.00x ONLINE /mnt
I can not see any data in /mnt/test ....
pool: oldboot
state: DEGRADED
flags.
