SOLVED ok I finally am ready to order
Darkflame
Intel Xeon E3-1230 v5 Boxed
€ 284
Supermicro X11SSM-F (Retail Pack)
€ 237,61
Cooltek Skall - Blauwe Led
€ 78
Kingston ValueRAM KVR21E15D8K2/16
€ 121,20
Corsair RM550x
€ 95,95
what do you guys think?
its a plex server with 4 3TB WD reds making sure I can put a second array of 4 HDDs in when need arises able to run 4k trans coding and up-gradable to 10Gb Ethernet in the future.
I also want to test out some jails when I get the time so I need it to be more than just a nas and plex server.
right now I am using an old xeon with 1333mhz FSB and some trans codes i get the warning i do not have the CPU power I do not like that! but want to get some approval of the forum members so i do not fuck up this kind of money.
wblock
Documentation Engineer
Has the memory been approved for that motherboard? It's two 8G, so if you need to go to 64G at some point you will have to replace it.
I have no experience with the Corsair power supplies, but the reviews of the RM550X are positive.
Darkflame
would you suggest a single 16gb stick over dual channel 2*8 ?
the ram is EEC non registered RAM i'm guessing it works how can i verify this?
melloa
Darkflame
i dont realy get the refrence if they say it needs DDR4 pc2133 and i get that type of ram im guessing its suposed to work no? never ever had anny issues
Darkflame
CPU • Intel® Xeon® E3-1200 v5 and 6th Gen Core™ i3, Pentium and Celeron processors in an LGA1151 (H4) socket. 80W max TDP. Memory • Four (4) 288-pin DIMM slots support up to 64 GB of SDRAM 72-bit DDR4 unbuffered ECC 2133/1866/1600/1333MHz memory
this is straight from the user manual
gpsguy
Active Member
If you go to the URL that melloa gave you in post #4, put in your model number, and look at the supported memory, you'll see this list for 16GB modules.
Darkflame
i see a recommended list indeed what i need to know is if the modules i listed will work.
Darkflame
It works!! my server is up and running running 40w idle comming down from 230 and 90w peak comming down from 290 :smile:
