I'm on core-13.0-U2 but got the same behavior when I was on core-12 too. The problem is that if I connect apc powershute on windows then I'm able to see more variables compared to truenas core and NUT-hidusb driver.
I can live without most of the missing vars but input.voltage would be useful to have. Any ideas how to make this work? I have also tried running apcupsd on opnsense and use the NUT-apcupsd driver on truenas but it does not change anything. I have seen others posting input.voltage for this ups on Linux so I assume NUT have the support but something is not configured as I want it on truenas. Any ideas where to look? I can't be the only one using this ups :)
rba@truenas:/ # upsc smc1000i-2u battery.charge: 100 battery.charge.low: 10 battery.charge.warning: 50 battery.runtime: 3000 battery.runtime.low: 120 battery.type: PbAc battery.voltage: 27.3 battery.voltage.nominal: 24.0 device.mfr: American Power Conversion device.model: Smart-UPS C 1000 device.serial: AS................ device.type: ups driver.name: usbhid-ups driver.parameter.pollfreq: 30 driver.parameter.pollinterval: 2 driver.parameter.port: /dev/ugen0.2 driver.parameter.synchronous: no driver.version: 2.7.4 driver.version.data: APC HID 0.96 driver.version.internal: 0.41 ups.beeper.status: disabled ups.delay.shutdown: 20 ups.firmware: UPS 14.0 / ID=1005 ups.mfr: American Power Conversion ups.mfr.date: 2015/05/19 ups.model: Smart-UPS C 1000 ups.productid: 0003 ups.serial: AS................ ups.status: OL ups.timer.reboot: -1 ups.timer.shutdown: -1 ups.vendorid: 051d
