NTFS volume import Problem
stof7
this is my 1rst attempt to run FreeNas (v8.2), the installation is done on an "old" Athlon X2 PC with 3 HDs,
I'm having trouble with NTFS import volume, it seems to be ok but it's not :
the volume seems to be mounted, exemple :
letera5 /mnt/letera5 129.4 MiB (0%) 1.4 TiB 1.4 TiB UNKNOWN (where unknown is the statut)
then when I clic on volume status, I just have a message that there is an error with explanation mark, that's it.
I've tried to format this disc several times in Gparted and windows7 but this doesn't change anything,
The thing is I need to keep it in NTFS to be able to transfer datas from the 2 other hard drives :
- One have 2 windows (XP 32 bits & 7 64 bits) + datas on a separate partition, all NTFS
- and the other is holding datas only, it is nearly full with 8OO/900 Go, just one partition, but dynamic NTFS volume.
I don't think that having some Windows system installed on one of the HD can cause a problem as FreeNAS is on separate USB key & anyway that disk is not mounted.
I would really appreciate some help there,
I know there has been several thread about NTFS volume import but I feel lost about it and because I don't see what is the error, and the GUI volume import is supposed to be working ok with NTFS now,
btw here is the console info I pasted :
FreeNAS™ © 2012 iXsystems, Inc.
Aug 13 10:04:35 freenas notifier: [: missing ]
Aug 13 10:04:44 freenas ntfsmount[2953]: Version 2.0.0 (libntfs 10:0:0)
Aug 13 10:04:44 freenas ntfsmount[2953]: Mounted /dev/ntfs/letera5 (Read-Write, label "letera5", NTFS version 3.1)
Aug 13 12:02:41 freenas newsyslog[1286]: logfile first created
Aug 13 12:02:41 freenas syslogd: kernel boot file is /boot/kernel/kernel
Aug 13 12:02:41 freenas kernel: Copyright (c) 1992-2011 The FreeBSD Project.
Aug 13 12:02:41 freenas kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Aug 13 12:02:41 freenas kernel: The Regents of the University of California. All rights reserved.
Aug 13 12:02:41 freenas kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
Aug 13 12:02:41 freenas kernel: FreeBSD 8.2-RELEASE-p9 #0: Thu Jul 19 16:02:19 PDT 2012
Aug 13 12:02:41 freenas kernel: root@build.ixsystems.com:/build/home/jpaetzel/8.2.0/os-base/i386/i386/build/home/jpaetzel/8.2.0/FreeBSD/src/sys/FREENAS.i386 i386
Aug 13 12:02:41 freenas kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
Aug 13 12:02:41 freenas kernel: CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ (2010.31-MHz 686-class CPU)
Aug 13 12:02:41 freenas kernel: Origin = "AuthenticAMD" Id = 0x20f32 Family = f Model = 23 Stepping = 2
Aug 13 12:02:41 freenas kernel: Features=0x178bfbff
Aug 13 12:02:41 freenas kernel: Features2=0x1
Aug 13 12:02:41 freenas kernel: AMD Features=0xe2500800
Aug 13 12:02:41 freenas kernel: AMD Features2=0x3
Aug 13 12:02:41 freenas kernel: real memory = 3221225472 (3072 MB)
Aug 13 12:02:41 freenas kernel: avail memory = 3143913472 (2998 MB)
Aug 13 12:02:41 freenas kernel: ACPI APIC Table:
Aug 13 12:02:41 freenas kernel: FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
Aug 13 12:02:41 freenas kernel: FreeBSD/SMP: 1 package(s) x 2 core(s)
Aug 13 12:02:41 freenas kernel: cpu0 (BSP): APIC ID: 0
Aug 13 12:02:41 freenas kernel: cpu1 (AP): APIC ID: 1
Aug 13 12:02:41 freenas kernel: WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
Aug 13 12:02:41 freenas kernel: ioapic0: Changing APIC ID to 2
Aug 13 12:02:41 freenas kernel: ioapic0 irqs 0-23 on motherboard
Aug 13 12:02:41 freenas kernel: kbd1 at kbdmux0
Aug 13 12:02:41 freenas kernel: cryptosoft0: on motherboard
Aug 13 12:02:41 freenas kernel: acpi0: on motherboard
Aug 13 12:02:41 freenas kernel: acpi0: [ITHREAD]
Aug 13 12:02:41 freenas kernel: acpi0: Power Button (fixed)
Aug 13 12:02:41 freenas kernel: acpi0: reservation of 0, a0000 (3) failed
Aug 13 12:02:41 freenas kernel: acpi0: reservation of 100000, bfef0000 (3) failed
Aug 13 12:02:41 freenas kernel: Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
Aug 13 12:02:41 freenas kernel: acpi_timer0: <24-bit timer at 3.579545MHz> port 0x4008-0x400b on acpi0
Aug 13 12:02:41 freenas kernel: cpu0: on acpi0
Aug 13 12:02:41 freenas kernel: cpu1: on acpi0
Aug 13 12:02:41 freenas kernel: acpi_button0: on acpi0
Aug 13 12:02:41 freenas kernel: pcib0: port 0xcf8-0xcff on acpi0
Aug 13 12:02:41 freenas kernel: pci0: on pcib0
Aug 13 12:02:41 freenas kernel: pci0: at device 0.0 (no driver attached)
Aug 13 12:02:41 freenas kernel: isab0: at device 1.0 on pci0
Aug 13 12:02:41 freenas kernel: isa0: on isab0
Aug 13 12:02:41 freenas kernel: pci0: at device 1.1 (no driver attached)
Aug 13 12:02:41 freenas kernel: ohci0: mem 0xd8104000-0xd8104fff irq 21 at device 2.0 on pci0
Aug 13 12:02:41 freenas kernel: ohci0: [ITHREAD]
Aug 13 12:02:41 freenas kernel: usbus0: on ohci0
Aug 13 12:02:41 freenas kernel: ehci0: mem 0xfeb00000-0xfeb000ff irq 22 at device 2.1 on pci0
Aug 13 12:02:41 freenas kernel: ehci0: [ITHREAD]
Aug 13 12:02:41 freenas kernel: usbus1: EHCI version 1.0
Aug 13 12:02:41 freenas kernel: usbus1: on ehci0
Aug 13 12:02:41 freenas kernel: pci0: at device 4.0 (no driver attached)
Aug 13 12:02:41 freenas kernel: atapci0: port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xf000-0xf00f at device 6.0 on pci0
Aug 13 12:02:41 freenas kernel: ata0: on atapci0
Aug 13 12:02:41 freenas kernel: ata0: [ITHREAD]
Aug 13 12:02:41 freenas kernel: ata1: on atapci0
Aug 13 12:02:41 freenas kernel: ata1: [ITHREAD]
Aug 13 12:02:41 freenas kernel: atapci1: port 0x9f0-0x9f7,0xbf0-0xbf3,0x970-0x977,0xb70-0xb73,0xd800-0xd80f mem 0xd8102000-0xd8102fff irq 21 at device 7.0 on pci0
Aug 13 12:02:41 freenas kernel: atapci1: [ITHREAD]
Aug 13 12:02:41 freenas kernel: ata2: on atapci1
Aug 13 12:02:41 freenas kernel: ata2: [ITHREAD]
Aug 13 12:02:41 freenas kernel: ata3: on atapci1
Aug 13 12:02:41 freenas kernel: ata3: [ITHREAD]
Aug 13 12:02:41 freenas kernel: atapci2: port 0x9e0-0x9e7,0xbe0-0xbe3,0x960-0x967,0xb60-0xb63,0xc400-0xc40f mem 0xd8101000-0xd8101fff irq 22 at device 8.0 on pci0
Aug 13 12:02:41 freenas kernel: atapci2: [ITHREAD]
Aug 13 12:02:41 freenas kernel: ata4: on atapci2
Aug 13 12:02:41 freenas kernel: ata4: [ITHREAD]
Aug 13 12:02:41 freenas kernel: ata5: on atapci2
Aug 13 12:02:41 freenas kernel: ata5: [ITHREAD]
Aug 13 12:02:41 freenas kernel: pcib1: at device 9.0 on pci0
Aug 13 12:02:41 freenas kernel: pci5: on pcib1
Aug 13 12:02:41 freenas kernel: pci5: at device 6.0 (no driver attached)
Aug 13 12:02:41 freenas kernel: fwohci0: mem 0xd8014000-0xd80147ff,0xd8010000-0xd8013fff irq 16 at device 11.0 on pci5
Aug 13 12:02:41 freenas kernel: fwohci0: [ITHREAD]
Aug 13 12:02:41 freenas kernel: fwohci0: OHCI version 1.10 (ROM=1)
Aug 13 12:02:41 freenas kernel: fwohci0: No. of Isochronous channels is 4.
Aug 13 12:02:41 freenas kernel: fwohci0: EUI64 00:11:d8:00:00:58:a8:0e
Aug 13 12:02:41 freenas kernel: fwohci0: Phy 1394a available S400, 2 ports.
Aug 13 12:02:41 freenas kernel: fwohci0: Link S400, max_rec 2048 bytes.
Aug 13 12:02:41 freenas kernel: firewire0: on fwohci0
Aug 13 12:02:41 freenas kernel: sbp0: on firewire0
Aug 13 12:02:41 freenas kernel: fwohci0: Initiate bus reset
Aug 13 12:02:41 freenas kernel: fwohci0: fwohci_intr_core: BUS reset
Aug 13 12:02:41 freenas kernel: fwohci0: fwohci_intr_core: node_id=0x00000000, SelfID Count=1, CYCLEMASTER mode
Aug 13 12:02:41 freenas kernel: nfe0: port 0xb000-0xb007 mem 0xd8100000-0xd8100fff irq 23 at device 10.0 on pci0
Aug 13 12:02:41 freenas kernel: miibus0: on nfe0
Aug 13 12:02:41 freenas kernel: e1000phy0: PHY 1 on miibus0
Aug 13 12:02:41 freenas kernel: e1000phy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
Aug 13 12:02:41 freenas kernel: nfe0: Ethernet address: 00:13:d4:9b:ee:7e
Aug 13 12:02:41 freenas kernel: nfe0: [FILTER]
Aug 13 12:02:41 freenas kernel: pcib2: at device 11.0 on pci0
Aug 13 12:02:41 freenas kernel: pci4: on pcib2
Aug 13 12:02:41 freenas kernel: pcib3: at device 12.0 on pci0
Aug 13 12:02:41 freenas kernel: pci3: on pcib3
Aug 13 12:02:41 freenas kernel: pcib4: at device 13.0 on pci0
Aug 13 12:02:41 freenas kernel: pci2: on pcib4
Aug 13 12:02:41 freenas kernel: pcib5: at device 14.0 on pci0
Aug 13 12:02:41 freenas kernel: pci1: on pcib5
Aug 13 12:02:41 freenas kernel: vgapci0: mem 0xd0000000-0xd3ffffff,0xc0000000-0xcfffffff,0xd4000000-0xd4ffffff irq 18 at device 0.0 on pci1
Aug 13 12:02:41 freenas kernel: amdtemp0: on hostb3
Aug 13 12:02:41 freenas kernel: acpi_tz0: on acpi0
Aug 13 12:02:41 freenas kernel: atrtc0: port 0x70-0x73 irq 8 on acpi0
Aug 13 12:02:41 freenas kernel: fdc0: port 0x3f0-0x3f5,0x3f7 irq 6 drq 2 on acpi0
Aug 13 12:02:41 freenas kernel: fdc0: [FILTER]
Aug 13 12:02:41 freenas kernel: uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
Aug 13 12:02:41 freenas kernel: uart0: [FILTER]
Aug 13 12:02:41 freenas kernel: uart0: console (9600,n,8,1)
Aug 13 12:02:41 freenas kernel: atkbdc0: port 0x60,0x64 irq 1 on acpi0
Aug 13 12:02:41 freenas kernel: atkbd0: irq 1 on atkbdc0
Aug 13 12:02:41 freenas kernel: kbd0 at atkbd0
Aug 13 12:02:41 freenas kernel: atkbd0: [GIANT-LOCKED]
Aug 13 12:02:41 freenas kernel: atkbd0: [ITHREAD]
Aug 13 12:02:41 freenas kernel: psm0: irq 12 on atkbdc0
Aug 13 12:02:41 freenas kernel: psm0: [GIANT-LOCKED]
Aug 13 12:02:41 freenas kernel: psm0: [ITHREAD]
Aug 13 12:02:41 freenas kernel: psm0: model IntelliMouse Explorer, device ID 4
Aug 13 12:02:41 freenas kernel: pmtimer0 on isa0
Aug 13 12:02:41 freenas kernel: orm0: at iomem 0xc0000-0xcefff,0xd0000-0xd3fff,0xd4000-0xd57ff pnpid ORM0000 on isa0
Aug 13 12:02:41 freenas kernel: sc0: at flags 0x100 on isa0
Aug 13 12:02:41 freenas kernel: sc0: VGA <16 virtual consoles, flags=0x300>
Aug 13 12:02:41 freenas kernel: vga0: at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Aug 13 12:02:41 freenas kernel: ppc0: parallel port not found.
Aug 13 12:02:41 freenas kernel: powernow0: on cpu0
Aug 13 12:02:41 freenas kernel: device_attach: powernow0 attach returned 6
Aug 13 12:02:41 freenas kernel: powernow1: on cpu1
Aug 13 12:02:41 freenas kernel: device_attach: powernow1 attach returned 6
Aug 13 12:02:41 freenas kernel: fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Aug 13 12:02:41 freenas kernel: Timecounters tick every 1.000 msec
Aug 13 12:02:41 freenas kernel: firewire0: 1 nodes, maxhop <= 0 cable IRM irm(0) (me)
Aug 13 12:02:41 freenas kernel: firewire0: bus manager 0
Aug 13 12:02:41 freenas kernel: usbus0: 12Mbps Full Speed USB v1.0
Aug 13 12:02:41 freenas kernel: usbus1: 480Mbps High Speed USB v2.0
Aug 13 12:02:41 freenas kernel: ugen0.1: at usbus0
Aug 13 12:02:41 freenas kernel: uhub0: on usbus0
Aug 13 12:02:41 freenas kernel: ugen1.1: at usbus1
Aug 13 12:02:41 freenas kernel: uhub1: on usbus1
Aug 13 12:02:41 freenas kernel: uhub0: 10 ports with 10 removable, self powered
Aug 13 12:02:41 freenas kernel: uhub1: 10 ports with 10 removable, self powered
Aug 13 12:02:41 freenas kernel: ugen1.2: at usbus1
Aug 13 12:02:41 freenas kernel: umass0: on usbus1
Aug 13 12:02:41 freenas kernel: ada0 at ata2 bus 0 scbus2 target 0 lun 0
Aug 13 12:02:41 freenas kernel: ada0: ATA-7da0 at umass-sim0 bus 0 scbus7 target 0 lun 0
Aug 13 12:02:41 freenas kernel: da0: < USB DISK 2.0 PMAP> Removable Direct Access SCSI-0 device
Aug 13 12:02:41 freenas kernel: da0: 40.000MB/s transfers
Aug 13 12:02:41 freenas kernel: da0: 7640MB (15646720 512 byte sectors: 255H 63S/T 973C)
Aug 13 12:02:41 freenas kernel: SATA 2.x device
Aug 13 12:02:41 freenas kernel: ada0: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
Aug 13 12:02:41 freenas kernel: ada0: 1430799MB (2930277168 512 byte sectors: 16H 63S/T 16383C)
Aug 13 12:02:41 freenas kernel: ada1 at ata4 bus 0 scbus4 target 0 lun 0
Aug 13 12:02:41 freenas kernel: ada1: ATA-8 SATA 2.x device
Aug 13 12:02:41 freenas kernel: ada1: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
Aug 13 12:02:41 freenas kernel: ada1: 476940MB (976773168 512 byte sectors: 16H 63S/T 16383C)
Aug 13 12:02:41 freenas kernel: ada2 at ata5 bus 0 scbus5 target 0 lun 0
Aug 13 12:02:41 freenas kernel: ada2: ATA-7 SATA 2.x device
Aug 13 12:02:41 freenas kernel: ada2: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
Aug 13 12:02:41 freenas kernel: ada2: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
Aug 13 12:02:41 freenas kernel: SMP: AP CPU #1 Launched!cd0 at ata0 bus 0 scbus0 target 0 lun 0
Aug 13 12:02:41 freenas kernel: cd0: Removable CD-ROM SCSI-0 device
Aug 13 12:02:41 freenas kernel: cd0: 66.700MB/s transfers (UDMA4, ATAPI 12bytes, PIO 65534bytes)
Aug 13 12:02:41 freenas kernel: cd0: Attempt to query device size failed: NOT READY, Medium not present
Aug 13 12:02:41 freenas kernel: GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
Aug 13 12:02:41 freenas kernel: Trying to mount root from ufs:/dev/ufs/FreeNASs1a
Aug 13 12:02:41 freenas root: /etc/rc: WARNING: Dump device does not exist. Savecore not run.
Aug 13 12:02:42 freenas ntpd[1512]: ntpd 4.2.4p5-a (1)
Aug 13 12:02:42 freenas root: /etc/rc: WARNING: failed precmd routine for vmware_guestd
Aug 13 10:02:49 freenas ntpd[1513]: time reset -7199.978238 s
Aug 13 10:02:59 freenas afpd[2207]: AFP/TCP started, advertising 192.168.1.5:548 (2.2.1)
Aug 13 10:03:03 freenas kernel: ZFS NOTICE: Prefetch is disabled by default on i386 -- to enable,
Aug 13 10:03:03 freenas kernel: add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
Aug 13 10:03:03 freenas kernel: ZFS WARNING: Recommended minimum kmem_size is 512MB; expect unstable behavior.
Aug 13 10:03:03 freenas kernel: Consider tuning vm.kmem_size and vm.kmem_size_max
Aug 13 10:03:03 freenas kernel: in /boot/loader.conf.
Aug 13 10:03:03 freenas kernel: ZFS filesystem version 4
Aug 13 10:03:03 freenas kernel: ZFS storage pool version 15
Olograph
Same Issue
I have a very similar problem, please someone respond.
I've imported a NTFS external usb drive converted to internal sata.
Volume displays as UNKNOWN with other informations but when I click on status it says an error occured.
stof7
I didn't find any solution to this ntfs import problem,
so I had to empty a whole drive (the biggest in size) and format it in UFS with FreeNAS,
then copy the datas from another ntfs drive to the UFS drive,
format this second drive in UFS and so on.
Sorry I can't help you, but I think FreeNAS team could try to investigate a little time about this NTFS import problem
Olograph
Thanks man as I'm concerned I'm switching for Ubuntu Server. I won't waste my time learning freebsd if I can dig further into linux.
Pick the undocumented and cryptic OS that suits you best lol
urcaGun
How to temporary change locale ? i need Cp2151 to view and copy my files from NTFS disk to NAS....
