NoVNC Broken Scale 22.12 BlueFin Beta 2?
NickF
Not sure if anyone else is experiencing this in BETA 2. I actually tried the first BETA and had the same exact issue, except none of the VMs worked. I waited for BETA 2 and am now reporting, as some of the VMs work now...but not all Some of my VMs have a problem where I can't get to the VNC window, and some don't. It's a really odd behavior.
When I press this:
I get this:
But when I press the same button on this one:
I get to the VM:
Problem goes away after reverting to TrueNAS-SCALE-22.02.3
NickF
Problem still exists in RC1, but now it's worse. I can't access the VNC monitor of any of my VMs.
New Ticket:
Old Ticket:
Was supposed to have been fixed here:
tprelog
I can't reach the display either
I installed my VM while on BETA 2 - I could access the display once but since I rebooted the host I get this error.
I just upgraded to RC 1 and the issue remains.
Looks like the new Jira ticket for RC 1 has already been marked closed by engineering but there is no fixed version listed.
EDIT: Ok, fixed version was listed under the BETA 2 issue and should be resolved in the release
morganL
Captain Morgan
Administrator
Found this thread after @NickF discussion on other thread.
So no evidence ist been fixed in 22.12.0?
@waqarahmed Is this replicable or do you see NoVNC working for you?
tprelog
There is another thread for the same issue, started on RC 1
I opened a new ticket after upgrading to the release and still not having VNC access
In my case, I can get VNC working (until I reboot SCALE) for my existing VM by restarting nginx
Forgot to mention - I can repeat this on a constant basis
Evan Richardson
confirmed this issue still exists in the release 22.12.0. Haven't tried restarting nginx yet though.
NickF
Just curious, I know it binds VNC to 0.0.0.0 by default. My Scale box is connected with a LACP LAG to my switch. It has several VLANS tagged/trunk and my management network is native/untagged.
I can externally connect to the VNC server for the individual vm computers.
Is yours also similar? I’m just trying to figure out why IX can’t repeat the issue on their end. Maybe nginx doesn’t like something in the way the network interface configuration is on my system and yours
morganL
Captain Morgan
Administrator
Confirmed that IX's normal VNC tests passed.
I'd suggest documenting the networking sets ups accurately on this thread. Also document what works, and what does not. I'll forward this thread to the engineering team so they can see whatever data you provide.
Evan Richardson
I have a bridge, br0 attached to my main nic. using 2 vlans, 192.168.1.0/24 and 192.168.4.6/29. This DID work in Scale Angelfish, only broke after the upgrade.
NickF
Hi, so, Just for clarity this is my config:
I didn't notice this but one of my interfaces is down, enp68s0f0. According to my switch it's been down about 10 days, which is about the time I was running RC1:
I shut/noshut the port and it's back. I have no idea why that interface was down??
But this seems wholly unrelated to the problem, and I am just documenting for the sake of full transparency of my troubleshooting.
In any case, I restarted nginx manually in the CLI, via
"systemctl reload nginx"
Which DID give me access into some of my VMs
But in others, I am getting 404 errors.
In the timeline of what I have seen, this is similar to the behavior I was seeing in BETA 2 before a change was made by Engineering, as documented in my original ticket. TThis is the pull request by the engineer assigned to the ticket: https://github.com/truenas/middleware/pull/10084
Since RC 1 and now 22.12.0 I was only seeing 500 errors, and not 404s.
Some further troubleshooting I did was to set the VNC address to something other than 0.0.0.0
But that does not appear to have made any impact.
NickF
I can only attach 10 pictures at a time. The next thing I noticed while down this rabbit hole is that on one of the affected VMs the "Device Order" for the "Display" device and "Network" device were duplicates, they had the same value. I'm not sure why this was:
But changing that also didn't have any affect.
I then tried restarting NGINX and still the same result with that change,
@morganL I hope that helps, I wish I had more information.
Also, for the record my NIC is an Intel X710-DA2. The ticket is also updated with my current information and new debug logs.
From a networking standpoint, to further clarify,
Switch:
The IP Alias terminates directly on bond0, and I can see the MAC address of the NICs in that VLAN.
NickF
restarting nginx solved this for me...now if it survives a reboot, that's a different story, but at least it works now =)
You can probably add that as an Init/Shutdown script
Which is under System Settings -> Advanced.
Just run
On POSTINIT.
I still have the problem outlined above, though.
tprelog
I've also noticed that I can connect to VNC using a client (KRDC) from my desktop even while the web based access gives 502 error. My configuration for the record... Nothing complicated, just the required bridge to allow VMs to access the NAS.
VM device list
And the VM setting for Network and display
TimB
I am seeing the same behavior, too. My setup is quite basic as well, basically the same as tprelog's. Nothing fancy. Restarting nginx service does fix it, but only until a reboot, as others have noted.
tprelog
If restarting nginx resolves the issue until reboot, there some good news...
I did TeamViewer with an ix-system employee and they were able to fix the issue on my NAS.
Another fix will be coming in 22.12.1
TimB
Awesome.
NickF
So progress seems to be made for some, but not for me specifically.
Per engineering, this change will be made in the next release, and you can "HotFix" it yourself by modifying a single line in a python script like the below:
Modified this file:
root@prod[/]# cd ./usr/lib/python3/dist-packages/middlewared/plugins/vm/
root@prod[.../dist-packages/middlewared/plugins/vm]# nano vm_display_info.py
Last line now reads:
return '127.0.0.1:700' instead of localhost.
You are then supposed to restart your server and it is supposed to resolve the issue. The pull request itself even states that the devs were confused as to why this resolves the problem, because it doesn't seem to make sense.
However, for me, the problem perists...
Anyone else??
tprelog
At this point, I'm guessing they must be different issues. Seems like fix you are referring to may only address the 502 Bad Gateway error
