Destari
- Feb 20, 2022
I have seen this brought up before, but nobody seems to have ever received an answer.
I have multiple notifications in TrueNAS Scale 23.10.1 that will not go away.
Dismissing them does nothing, you can see they are more than a year old now. They also carry over when exporting/importing my configuration file so a reinstall that occurred in late 2023 didn't even solve the issue... That VMWare integration entry doesn't exist anymore, it was deleted, and there is no longer an ESXi server at those addresses.
I have found this issue historically has existed on multiple versions of TrueNAS Scale, Core and even FreeNAS for other types of notifications:
www.truenas.com
www.truenas.com
Is there a way to clear this manually? The fact that it carries over through a reinstall is by far the most frustrating thing.
Thank you in advance for any help.
Notifications won't go away
Hi all! This is a minor problem I'm having. I would like to remove a couple of notifications that are permanently showing (more than one year). Is there any way of removing them? May be manually? Both of these task were removed some time ago, they actually don't exist. Thank you! Kind regards...
Cloud sync task Alert won't go away
Hi im running FreeNAS-11.3-U3.2 and have one alert which won't disappear. I had a Cloud Sync Tak wich didn't work as intended so i deleted it after many trys, but the Alert is still here. Rebooting in both states doesn't delete it. Changing the Alert Settings does affect it after...
