Not seeing an answer to this. Help? Sonarr Connect to SABnzbd
rob90033
When trying to connect Sonarr to SABnzbd i get an error of Test was aborted due to an error: Unable to connect to SABnzbd, please check your settings. I have verified the settings are right. This worked on Unraid but maybe there some sort of difference using jails?
What do the Sonarr logs say?
rob90033
Invalid request Validation failed:
-- Unable to connect to SABnzbd
-- Test was aborted due to an error: Unable to connect to SABnzbd, please check your settings
rob90033
crap, i tried to setup SABnzbd host from 0.0.0.0 to my ip and now i get refused to connect error. i have been trying to find a guide/howto for Truenas 12 but have only found older stuff...
Need more info. There are no difference using jails.
I suspect that sab isn't listening on the right ip or something similar.
You can probably avoid alot of these issues by installing all this similar softwares in the same jail. Having 10 different jails running a single program is very inefficient IMHO.
rob90033
Ooooh... Complete noob here didn't know you could do that.
