not able to install apps on scale
MadMan3353
everytime i go to install an app whether is offical or ture charts i receive this error. any suggestions on what may be causing this? seems like ever since i created a bridge for my VM i've had an issue with the kuberbnetes and yes i made the required changes for the kubernetes to use the the br0.
I would suggest going to Apps | Settings | Unset Pool, then go back in and set the pool again.
Assuming you didn't yet have any apps.
With kubernetes not running, you're not going to get far with apps.
I suggest wasting time figuring that out may not be productive, so just make sure you have a config backup and reinstall (or activate your previous boot environment and see if that puts it back to good.
