Not able to boot any VM´s
robert_l
Hi
I´m suddenly not able to start/boot any VM´s on truenas scale (22.12)
VM´s running legacy bios is reporting "No bootable device"
robert_l
Hi
Logfile:
2022-08-07 13:33:27.805+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.79+truenas, hostname: truenas.local
LC_ALL=C \
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin \
HOME=/var/lib/libvirt/qemu/domain-6-7_libre1 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-6-7_libre1/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-6-7_libre1/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-6-7_libre1/.config \
QEMU_AUDIO_DRV=none \
/usr/bin/qemu-system-x86_64 \
-name guest=7_libre1,debug-threads=on \
-S \
-object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-6-7_libre1/master-key.aes \
-machine pc-i440fx-5.2,accel=kvm,usb=off,dump-guest-core=off,memory-backend=pc.ram \
-cpu qemu64 \
-m 4096 \
-object memory-backend-ram,id=pc.ram,size=4294967296 \
-overcommit mem-lock=off \
-smp 4,sockets=1,dies=1,cores=2,threads=2 \
-uuid 3c3f0255-d7c9-46b6-aefe-e11ca3bb4753 \
-no-user-config \
-nodefaults \
-chardev socket,id=charmonitor,fd=52,server,nowait \
-mon chardev=charmonitor,id=monitor,mode=control \
-rtc base=localtime \
-no-shutdown \
-boot strict=on \
-device nec-usb-xhci,id=usb,bus=pci.0,addr=0x4 \
-device ahci,id=sata0,bus=pci.0,addr=0x5 \
-blockdev '{"driver":"host_device","filename":"/dev/zvol/ZData/VM-SLOW/libre1","aio":"threads","node-name":"libvirt-1-storage","cache":{"direct":true,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-1-format","read-only":false,"cache":{"direct":true,"no-flush":false},"driver":"raw","file":"libvirt-1-storage"}' \
-device ide-hd,bus=sata0.0,drive=libvirt-1-format,id=sata0-0-0,bootindex=1,write-cache=on \
-netdev tap,fd=57,id=hostnet0,vhost=on,vhostfd=58 \
-device virtio-net-pci,netdev=hostnet0,id=net0,mac=00:a0:98:72:a9:a9,bus=pci.0,addr=0x3 \
-chardev pty,id=charserial0 \
-device isa-serial,chardev=charserial0,id=serial0 \
-device usb-tablet,id=input0,bus=usb.0,port=1 \
-vnc 0.0.0.0:10 \
-device qxl-vga,id=video0,ram_size=67108864,vram_size=67108864,vram64_size_mb=0,vgamem_mb=16,max_outputs=1,xres=1024,yres=768,bus=pci.0,addr=0x2 \
-device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x6 \
-sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \
-msg timestamp=on
char device redirected to /dev/pts/5 (label charserial0)
2022-08-07T13:36:06.809754Z qemu-system-x86_64: terminating on signal 15 from pid 9422 (/usr/sbin/libvirtd)
2022-08-07 13:36:07.210+0000: shutting down, reason=destroyed
2022-08-07 13:40:10.299+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.79+truenas, hostname: truenas.local
LC_ALL=C \
HOME=/var/lib/libvirt/qemu/domain-7-7_libre1 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-7-7_libre1/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-7-7_libre1/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-7-7_libre1/.config \
-S \
-object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-7-7_libre1/master-key.aes \
-cpu qemu64 \
-m 4096 \
-no-user-config \
-nodefaults \
-no-shutdown \
-boot strict=on \
-vnc 0.0.0.0:10 \
-msg timestamp=on
char device redirected to /dev/pts/6 (label charserial0)
2022-12-24T14:12:16.784809Z qemu-system-x86_64: terminating on signal 15 from pid 9422 (/usr/sbin/libvirtd)
2022-12-24 14:12:17.769+0000: shutting down, reason=shutdown
2022-12-24 22:51:24.906+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.79+truenas, hostname: truenas.local
LC_ALL=C \
HOME=/var/lib/libvirt/qemu/domain-2-7_libre1 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-2-7_libre1/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-2-7_libre1/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-2-7_libre1/.config \
-S \
-object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-2-7_libre1/master-key.aes \
-cpu qemu64 \
-m 4096 \
-no-user-config \
-nodefaults \
-chardev socket,id=charmonitor,fd=36,server,nowait \
-no-shutdown \
-boot strict=on \
-netdev tap,fd=41,id=hostnet0,vhost=on,vhostfd=42 \
-vnc 0.0.0.0:10 \
-msg timestamp=on
char device redirected to /dev/pts/1 (label charserial0)
2022-12-24T22:53:16.386390Z qemu-system-x86_64: terminating on signal 15 from pid 14137 (/usr/sbin/libvirtd)
2022-12-24 22:53:16.835+0000: shutting down, reason=shutdown
2022-12-24 23:00:45.439+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.79+truenas, hostname: truenas.local
LC_ALL=C \
HOME=/var/lib/libvirt/qemu/domain-5-7_libre1 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-5-7_libre1/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-5-7_libre1/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-5-7_libre1/.config \
-S \
-object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-5-7_libre1/master-key.aes \
-cpu qemu64 \
-m 4096 \
-no-user-config \
-nodefaults \
-chardev socket,id=charmonitor,fd=48,server,nowait \
-no-shutdown \
-boot strict=on \
-netdev tap,fd=53,id=hostnet0,vhost=on,vhostfd=54 \
-vnc 0.0.0.0:10 \
-msg timestamp=on
char device redirected to /dev/pts/4 (label charserial0)
2022-12-24T23:06:02.570476Z qemu-system-x86_64: terminating on signal 15 from pid 12194 (/usr/sbin/libvirtd)
2022-12-24 23:06:03.420+0000: shutting down, reason=shutdown
2022-12-24 23:11:39.596+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.79+truenas, hostname: truenas.local
LC_ALL=C \
-S \
-cpu qemu64 \
-m 4096 \
-no-user-config \
-nodefaults \
-no-shutdown \
-boot strict=on \
-vnc 0.0.0.0:10 \
-msg timestamp=on
2022-12-24T23:13:49.885959Z qemu-system-x86_64: terminating on signal 15 from pid 12188 (/usr/sbin/libvirtd)
2022-12-24 23:13:50.434+0000: shutting down, reason=shutdown
2022-12-24 23:22:00.201+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.79+truenas, hostname: truenas.local
LC_ALL=C \
-S \
-cpu qemu64 \
-m 4096 \
-no-user-config \
-nodefaults \
-no-shutdown \
-boot strict=on \
-vnc 0.0.0.0:10 \
-msg timestamp=on
2023-01-10 19:48:45.692+0000: shutting down, reason=crashed
2023-01-10 21:05:20.222+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.79+truenas, hostname: truenas.local
LC_ALL=C \
-S \
-cpu qemu64 \
-m 4096 \
-no-user-config \
-nodefaults \
-no-shutdown \
-boot strict=on \
-vnc 0.0.0.0:10 \
-msg timestamp=on
2023-01-11T18:15:19.862517Z qemu-system-x86_64: terminating on signal 15 from pid 14103 (/usr/sbin/libvirtd)
2023-01-11 18:15:20.263+0000: shutting down, reason=destroyed
2023-01-11 18:22:44.655+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.79+truenas, hostname: truenas.local
LC_ALL=C \
-S \
-cpu qemu64 \
-m 4096 \
-no-user-config \
-nodefaults \
-no-shutdown \
-boot strict=on \
-vnc 0.0.0.0:10 \
-msg timestamp=on
2023-01-11T19:43:23.612770Z qemu-system-x86_64: terminating on signal 15 from pid 13094 (/usr/sbin/libvirtd)
2023-01-11 19:43:24.013+0000: shutting down, reason=destroyed
2023-01-11 19:52:27.835+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.79+truenas, hostname: truenas.local
LC_ALL=C \
HOME=/var/lib/libvirt/qemu/domain-3-7_libre1 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-3-7_libre1/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-3-7_libre1/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-3-7_libre1/.config \
-S \
-object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-3-7_libre1/master-key.aes \
-cpu qemu64 \
-m 4096 \
-no-user-config \
-nodefaults \
-chardev socket,id=charmonitor,fd=35,server,nowait \
-no-shutdown \
-boot strict=on \
-netdev tap,fd=37,id=hostnet0,vhost=on,vhostfd=38 \
-vnc 0.0.0.0:10 \
-msg timestamp=on
char device redirected to /dev/pts/0 (label charserial0)
2023-01-11T19:54:43.516553Z qemu-system-x86_64: terminating on signal 15 from pid 12714 (/usr/sbin/libvirtd)
2023-01-11 19:54:43.917+0000: shutting down, reason=destroyed
2023-01-11 19:55:05.221+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.79+truenas, hostname: truenas.local
LC_ALL=C \
HOME=/var/lib/libvirt/qemu/domain-4-7_libre1 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-4-7_libre1/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-4-7_libre1/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-4-7_libre1/.config \
-S \
-object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-4-7_libre1/master-key.aes \
-blockdev '{"driver":"file","filename":"/usr/share/OVMF/OVMF_CODE.fd","node-name":"libvirt-pflash0-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-pflash0-format","read-only":true,"driver":"raw","file":"libvirt-pflash0-storage"}' \
-blockdev '{"driver":"file","filename":"/var/lib/libvirt/qemu/nvram/7_libre1_VARS.fd","node-name":"libvirt-pflash1-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-pflash1-format","read-only":false,"driver":"raw","file":"libvirt-pflash1-storage"}' \
-machine pc-i440fx-5.2,accel=kvm,usb=off,dump-guest-core=off,pflash0=libvirt-pflash0-format,pflash1=libvirt-pflash1-format,memory-backend=pc.ram \
-cpu qemu64 \
-m 4096 \
-no-user-config \
-nodefaults \
-no-shutdown \
-boot strict=on \
-vnc 0.0.0.0:10 \
-msg timestamp=on
2023-01-11T19:55:48.720105Z qemu-system-x86_64: warning: no scancode found for keysym 168
2023-01-11T19:55:48.720170Z qemu-system-x86_64: warning: no scancode found for keysym 168
2023-01-11T19:56:00.844543Z qemu-system-x86_64: terminating on signal 15 from pid 12714 (/usr/sbin/libvirtd)
2023-01-11 19:56:01.245+0000: shutting down, reason=destroyed
2023-01-11 19:56:20.751+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.79+truenas, hostname: truenas.local
LC_ALL=C \
-S \
-cpu qemu64 \
-m 4096 \
-no-user-config \
-nodefaults \
-no-shutdown \
-boot strict=on \
-vnc 0.0.0.0:10 \
-msg timestamp=on
2023-01-11T19:56:33.447426Z qemu-system-x86_64: terminating on signal 15 from pid 12714 (/usr/sbin/libvirtd)
2023-01-11 19:56:33.648+0000: shutting down, reason=destroyed
2023-01-11 20:54:11.236+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.79+truenas, hostname: truenas.local
LC_ALL=C \
HOME=/var/lib/libvirt/qemu/domain-21-7_libre1 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-21-7_libre1/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-21-7_libre1/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-21-7_libre1/.config \
-S \
-object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-21-7_libre1/master-key.aes \
-cpu qemu64 \
-m 4096 \
-no-user-config \
-nodefaults \
-no-shutdown \
-boot strict=on \
-device ide-hd,bus=sata0.0,drive=libvirt-1-format,id=sata0-0-0,bootindex=1,logical_block_size=512,physical_block_size=512,write-cache=on \
-vnc 0.0.0.0:10 \
-msg timestamp=on
char device redirected to /dev/pts/2 (label charserial0)
2023-01-11T20:55:26.362098Z qemu-system-x86_64: terminating on signal 15 from pid 12714 (/usr/sbin/libvirtd)
2023-01-11 20:55:26.762+0000: shutting down, reason=destroyed
Stolen_Walnut
You have a number of "shutting down, reason=destroyed"'s in there. The one previous is a "shutting down, reason=crashed". Any idea if there was something changed in the VM around Jan 10?
Any snapshots you can rollback to?
One thing I've found helpful is to create a new VM, and then provide the block device from the crashed VM to it to poke around the root filesystem. Sometimes the logs in there will clue you in on something, or at very least you can grab your important data
