No volumes in GUI, system completely functional
crusader27529
I was informed by my power provider of a planned shutdown, so I dutifully took down my FreeNAS system before the outage.
Strangely, after the outage, the system if functional, but the GUI doesn't show any volumes, so it can't show the content of the system.
The reporting tab shows the disk activity and the partition data correctly.
The system works fine, has only CIFS access, and each volume only has one partition.
I'm running 9.10 with a LSI controller in IT mode. Without being able to see the volumes and therefore the drives in the volume, I think that I can't replace a drive if it failed........the command line is not my friend unless I get a precise command to execute.
I can supply whatever data you need, as long as I get command line stuff with details.
YES, I did take the system down and bring it back up already.
crusader27529
Here you go:
login as: root
root@freenas.local's password:
Last login: Sun Dec 29 10:25:58 2019 from 192.168.1.166
FreeBSD 10.3-RELEASE (FreeNAS.amd64) #0 1b72f49(HEAD): Wed Apr 13 23:35:10 PDT 2016
FreeNAS (c) 2009-2016, The FreeNAS Development Team
All rights reserved.
FreeNAS is released under the modified BSD license.
For more information, documentation, help or support, go here:
http://freenas.org
Welcome to FreeNAS
[root@freenas] ~# zpool status
pool: backup
state: ONLINE
scan: scrub repaired 0 in 3h30m with 0 errors on Sat Feb 15 05:30:54 2020
NAME STATE READ WRITE CKSUM
backup ONLINE 0 0 0
gptid/af160cf8-212d-11ea-b357-003048f10bcc ONLINE 0 0 0
errors: No known data errors
pool: dotsystem
state: ONLINE
scan: scrub repaired 0 in 0h0m with 0 errors on Mon Jan 13 02:00:09 2020
dotsystem ONLINE 0 0 0
gptid/c49686f1-1d06-11ea-a1be-003048f10bcc ONLINE 0 0 0
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0h0m with 0 errors on Thu Feb 6 22:06:06 2020
freenas-boot ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
ada1p2 ONLINE 0 0 0
pool: housedata
state: ONLINE
scan: scrub repaired 0 in 3h11m with 0 errors on Mon Feb 10 03:12:02 2020
housedata ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/7bf0b723-398f-11ea-a438-003048f10bcc ONLINE 0 0 0
gptid/804a5fa7-398f-11ea-a438-003048f10bcc ONLINE 0 0 0
gptid/841d6bfd-398f-11ea-a438-003048f10bcc ONLINE 0 0 0
gptid/887b5e00-398f-11ea-a438-003048f10bcc ONLINE 0 0 0
[root@freenas] ~#
[root@freenas] ~#
[root@freenas] ~# zpool import
[root@freenas] ~#
Pools are there...
Maybe you need a forced refresh of the GUI in the browser... usually SHIFT-Reload.
crusader27529
As part of the daily security run output, this was there, obviously from the last reboot:
freenas.local kernel log messages:
ugen0.2: <USB> at usbus0
ukbd0: <USB USB Keykoard, class 0/0, rev 1.10/1.10, addr 2> on usbus0
kbd2 at ukbd0
da0: <ATA ST3160318AS CC46> Fixed Direct Access SPC-4 SCSI device
da1 at mps0 bus 0 scbus0 target 1 lun 0
da1: <ATA Hitachi HUA72302 AA10> Fixed Direct Access SPC-4 SCSI device
da1: Serial Number MK0151YFKMJ59A
da1: 600.000MB/s transfers
da1: Command Queueing enabled
da1: 1907729MB (3907029168 512 byte sectors)
da0: Serial Number 5VMPZJ4Q
da0: 300.000MB/s transfers
da0: Command Queueing enabled
da0: 152587MB (312500000 512 byte sectors)
da2 at mps0 bus 0 scbus0 target 2 lun 0
da2: <ATA HGST HUS724020AL AA70> Fixed Direct Access SPC-4 SCSI device
SMP: AP CPU #6 Launched!
Timecounter "TSC" frequency 2000110482 Hz quality 1000
(da1:mps0:0:1:0): READ(6). CDB: 08 00 02 80 10 00
Trying to mount root from zfs:freenas-boot/ROOT/default []...
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 00 00 00 00 01 00 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 00 01 00 00 01 00 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 e8 e0 85 00 00 01 00 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 e8 e0 87 00 00 01 00 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 40 00 80 00 01 00 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 3f fc 80 00 01 00 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 3f fd 80 00 01 00 00
(da1:mps0:0:1:0): CAM status: SCSI Status Error
(da1:mps0:0:1:0): SCSI status: Check Condition
(da1:mps0:0:1:0): SCSI sense: ABORTED COMMAND asc:47,3 (Information unit iuCRC error detected)
(da1:mps0:0:1:0): Retrying command (per sense data)
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 00 01 80 00 01 00 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 3f fe 80 00 01 00 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 3f ff 80 00 01 00 00
GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
em0: link state changed to UP
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 40 02 a0 00 00 e0 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 e8 e0 84 a0 00 00 e0 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 40 01 d0 00 00 b0 00 length 90112 SMID 461 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 40 03 80 00 01 00 00 length 131072 SMID 462 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 e8 e0 85 80 00 01 00 00 length 131072 SMID 463 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 40 01 b0 00 00 08 00 length 4096 SMID 415 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 40 01 b8 00 00 08 00 length 4096 SMID 416 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 40 01 c0 00 00 08 00 length 4096 SMID 417 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 40 01 c8 00 00 08 00 length 4096 SMID 418 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 40 01 a8 00 00 08 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 40 01 a8 00 00 08 00 length 4096 SMID 466 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 40 01 b0 00 00 08 00 length 4096 SMID 467 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 40 01 b8 00 00 08 00 length 4096 SMID 468 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 40 01 c0 00 00 08 00 length 4096 SMID 469 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 40 01 c8 00 00 08 00 length 4096 SMID 470 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 e8 e0 85 80 00 01 00 00 length 131072 SMID 472 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 e8 e0 85 80 00 01 00 00 length 131072 SMID 584 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 40 03 80 00 01 00 00 length 131072 SMID 604 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 e8 e0 85 80 00 01 00 00 length 131072 SMID 605 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 e8 e0 87 80 00 01 00 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 b4 40 d5 a0 00 00 30 00 length 24576 SMID 656 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 b4 40 d5 90 00 00 10 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 97 1c 48 00 00 08 00 length 4096 SMID 698 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 03 0b 4c 68 00 00 08 00 length 4096 SMID 734 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 03 0b 4c 50 00 00 08 00
hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/2/40/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/40/0x67<INT,USR,SYS,REA,WRI>
em0: link state changed to DOWN
uhid0: <USB USB Keykoard, class 0/0, rev 1.10/1.10, addr 2> on usbus0
vboxdrv: fAsync=0 offMin=0x71a offMax=0x1aa6
GEOM_ELI: Device da0p1.eli created.
GEOM_ELI: Encryption: AES-XTS 128
GEOM_ELI: Crypto: software
GEOM_ELI: Device da5p1.eli created.
GEOM_ELI: Device da1p1.eli created.
GEOM_ELI: Device da2p1.eli created.
GEOM_ELI: Device da3p1.eli created.
GEOM_ELI: Device da4p1.eli created.
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 00 02 80 00 01 00 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 00 00 03 80 00 01 00 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 4a 90 d0 00 00 70 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 51 17 30 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 59 34 78 00 00 80 00 length 65536 SMID 864 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 4c 1a 08 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 59 34 78 00 00 80 00 length 65536 SMID 693 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 59 34 78 00 00 80 00 length 65536 SMID 866 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 59 34 78 00 00 80 00 length 65536 SMID 870 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 74 da e0 00 00 08 00 length 4096 SMID 904 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 74 e0 20 00 00 08 00 length 4096 SMID 908 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 4a 90 40 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 52 9e 90 00 00 80 00 length 65536 SMID 935 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 52 9d 88 00 00 80 00 length 65536 SMID 926 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 54 9a 38 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 65 a1 c8 00 00 80 00 length 65536 SMID 991 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 5e b4 68 00 00 80 00 length 65536 SMID 985 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 65 a2 d0 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 5e b4 68 00 00 80 00 length 65536 SMID 1001 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 6e f5 e8 00 00 80 00 length 65536 SMID 63 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 67 5a 50 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 67 5a 50 00 00 80 00 length 65536 SMID 68 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 6e f5 e8 00 00 80 00 length 65536 SMID 71 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 71 91 90 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 71 92 98 00 00 80 00 length 65536 SMID 82 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 6e f5 e8 00 00 80 00 length 65536 SMID 78 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 52 9f 98 00 00 80 00 length 65536 SMID 88 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 4e bc c0 00 00 80 00 length 65536 SMID 86 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 57 70 c8 00 00 80 00 length 65536 SMID 107 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 62 9c a0 00 00 80 00 length 65536 SMID 109 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 59 36 88 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 68 96 e8 00 00 80 00 length 65536 SMID 117 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 6e f7 f8 00 00 80 00 length 65536 SMID 116 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 6e f7 f8 00 00 80 00 length 65536 SMID 123 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 73 da 18 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 73 d9 10 00 00 80 00 length 65536 SMID 354 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 57 71 d0 00 00 80 00 length 65536 SMID 358 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 63 fd 88 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 63 fd 88 00 00 80 00 length 65536 SMID 362 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 57 71 d0 00 00 80 00 length 65536 SMID 363 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 73 d9 10 00 00 80 00 length 65536 SMID 372 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 57 71 d0 00 00 80 00 length 65536 SMID 374 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 63 fd 88 00 00 80 00 length 65536 SMID 366 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 57 71 d0 00 00 80 00 length 65536 SMID 376 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 60 c1 10 00 00 80 00 length 65536 SMID 381 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 57 71 d0 00 00 80 00 length 65536 SMID 379 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 71 95 b0 00 00 80 00 length 65536 SMID 602 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 65 a4 e0 00 00 80 00 length 65536 SMID 611 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 6e f9 00 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 6e f9 00 00 00 80 00 length 65536 SMID 534 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 65 a4 e0 00 00 80 00 length 65536 SMID 615 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 71 95 b0 00 00 80 00 length 65536 SMID 621 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 65 a4 e0 00 00 80 00 length 65536 SMID 617 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 62 4d 08 00 00 80 00 length 65536 SMID 884 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 62 4b 78 00 00 80 00 length 65536 SMID 890 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 55 6f d0 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 41 5b d8 00 00 80 00 length 65536 SMID 914 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 62 4b 78 00 00 80 00 length 65536 SMID 883 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 41 5b 50 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 48 62 78 00 00 80 00 length 65536 SMID 937 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 48 63 80 00 00 80 00 length 65536 SMID 945 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 48 64 88 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 4d e8 98 00 00 80 00 length 65536 SMID 952 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 4c 7d 30 00 00 80 00 length 65536 SMID 964 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 50 79 f8 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 50 7b 00 00 00 80 00 length 65536 SMID 68 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 50 79 f8 00 00 80 00 length 65536 SMID 999 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 50 7c 08 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 53 79 68 00 00 80 00 length 65536 SMID 1019 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 50 79 f8 00 00 80 00 length 65536 SMID 73 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 53 7b 78 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 58 98 98 00 00 80 00 length 65536 SMID 103 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 50 79 f8 00 00 80 00 length 65536 SMID 90 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 58 97 90 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 5d e3 00 00 00 80 00 length 65536 SMID 111 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 58 97 90 00 00 80 00 length 65536 SMID 101 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 50 79 f8 00 00 80 00 length 65536 SMID 105 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 58 97 90 00 00 80 00 length 65536 SMID 107 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 58 97 90 00 00 80 00 length 65536 SMID 99 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 5d e3 00 00 00 80 00 length 65536 SMID 115 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 53 7d 88 00 00 80 00 length 65536 SMID 132 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 49 c8 f8 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 49 c8 f8 00 00 80 00 length 65536 SMID 129 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 49 c8 f8 00 00 80 00 length 65536 SMID 152 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 51 ed 38 00 00 80 00 length 65536 SMID 161 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 51 ec 30 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 51 ed 38 00 00 80 00 length 65536 SMID 166 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 51 ed c0 00 00 80 00 length 65536 SMID 180 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 60 68 48 00 00 80 00 length 65536 SMID 197 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 51 ed c0 00 00 80 00 length 65536 SMID 187 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 57 02 f0 00 00 80 00 length 65536 SMID 235 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 60 6b f0 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 60 6b f0 00 00 80 00 length 65536 SMID 248 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 5d e5 20 00 00 80 00 length 65536 SMID 281 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 43 dd f0 00 00 80 00 length 65536 SMID 275 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 55 73 70 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 43 de f8 00 00 80 00 length 65536 SMID 259 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 55 73 70 00 00 80 00 length 65536 SMID 302 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 48 68 30 00 00 80 00 length 65536 SMID 313 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 48 66 20 00 00 80 00 length 65536 SMID 316 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 48 67 28 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 48 66 20 00 00 80 00 length 65536 SMID 301 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 48 67 28 00 00 80 00 length 65536 SMID 305 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 4f 3f 38 00 00 80 00 length 65536 SMID 361 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 4f 40 40 00 00 80 00 length 65536 SMID 373 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 4c 86 80 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 64 a4 30 00 00 80 00 length 65536 SMID 601 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 64 a5 38 00 00 80 00 length 65536 SMID 612 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 58 9d 48 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 58 9d 48 00 00 80 00 length 65536 SMID 616 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 64 a5 38 00 00 80 00 length 65536 SMID 602 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 45 75 d8 00 00 80 00 length 65536 SMID 634 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 64 a5 38 00 00 80 00 length 65536 SMID 623 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 64 a5 c8 00 00 80 00
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 48 6b 48 00 00 80 00 length 65536 SMID 637 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 53 7f 18 00 00 80 00 length 65536 SMID 645 terminated ioc 804b scsi 0 state 0 xfer 0
(da1:mps0:0:1:0): READ(10). CDB: 28 00 72 60 6e 00 00 00 80 00
(da1:mps0:0:1:0): WRITE(10). CDB: 2a 00 e8 e0 87 c0 00 00 08 00 length 4096 SMID 210 terminated ioc 804b scsi 0 state c xfer 0
(da1:mps0:0:1:0): WRITE(10). CDB: 2a 00 00 40 03 c0 00 00 08 00 length 4096 SMID 222 terminated ioc 804b scsi 0 state c xfer 0
(da1:mps0:0:1:0): WRITE(10). CDB: 2a 00 00 40 01 c0 00 00 08 00 length 4096 SMID 220 terminated ioc 804b scsi 0 state c xfer 0
(da1:mps0:0:1:0): WRITE(10). CDB: 2a 00 e8 e0 85 c0 00 00 08 00 length 4096 SMID 221 terminated ioc 804b scsi 0 state c xfer 0
(da1:mps0:0:1:0): WRITE(10). CDB: 2a 00 8c 40 2a 70 00 00 08 00
I don't know how to interpret it.
da1 is in trouble, either due to bad cabling or an internal disk problem.
What do you get from smartctl -a /dev/da1 ?
crusader27529
I see some issues with da1, but how does that figure in to the GUI issue?
[root@freenas] ~# smartctl -a /dev/da1
smartctl 6.4 2015-06-04 r4109 [FreeBSD 10.3-RELEASE amd64] (local build)
Copyright (C) 2002-15, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Hitachi Ultrastar 7K3000
Device Model: Hitachi HUA723020ALA640
Serial Number: MK0151YFKMJ59A
LU WWN Device Id: 5 000cca 223f32644
Firmware Version: MK7OAA10
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 2.6, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Feb 17 11:00:03 2020 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 28) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 325) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 133 133 054 Pre-fail Offline - 91
3 Spin_Up_Time 0x0007 205 205 024 Pre-fail Always - 333 (Average 276)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 185
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 125 125 020 Pre-fail Offline - 30
9 Power_On_Hours 0x0012 099 099 000 Old_age Always - 13991
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 47
192 Power-Off_Retract_Count 0x0032 098 098 000 Old_age Always - 3447
193 Load_Cycle_Count 0x0012 098 098 000 Old_age Always - 3447
194 Temperature_Celsius 0x0002 206 206 000 Old_age Always - 29 (Min/Max 19/58)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 870
SMART Error Log Version: 1
ATA Error Count: 958 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 958 occurred at disk power-on lifetime: 13972 hours (582 days + 4 hours)
ER ST SC SN CL CH DH
84 51 11 6f 6e 60 02 Error: ICRC, ABRT at LBA = 0x02606e6f = 39874159
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 80 10 00 6e 60 40 00 00:52:06.701 READ FPDMA QUEUED
60 80 10 f8 6c 60 40 00 00:52:06.697 READ FPDMA QUEUED
60 80 10 20 80 53 40 00 00:52:06.694 READ FPDMA QUEUED
60 80 08 18 7f 53 40 00 00:52:06.694 READ FPDMA QUEUED
60 80 00 48 6b 48 40 00 00:52:06.689 READ FPDMA QUEUED
Error 957 occurred at disk power-on lifetime: 13972 hours (582 days + 4 hours)
84 51 11 37 a6 64 02 Error: ICRC, ABRT at LBA = 0x0264a637 = 40150583
60 80 08 d8 75 45 40 00 00:52:06.676 READ FPDMA QUEUED
60 80 00 c8 a5 64 40 00 00:52:06.669 READ FPDMA QUEUED
60 80 10 38 a5 64 40 00 00:52:06.660 READ FPDMA QUEUED
60 80 08 30 a4 64 40 00 00:52:06.660 READ FPDMA QUEUED
60 80 00 48 9d 58 40 00 00:52:06.660 READ FPDMA QUEUED
Error 956 occurred at disk power-on lifetime: 13972 hours (582 days + 4 hours)
84 51 21 8f a4 64 02 Error: ICRC, ABRT at LBA = 0x0264a48f = 40150159
60 80 10 38 a5 64 40 00 00:52:06.653 READ FPDMA QUEUED
60 80 08 48 9d 58 40 00 00:52:06.653 READ FPDMA QUEUED
60 80 00 30 a4 64 40 00 00:52:06.652 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 00:52:06.652 READ LOG EXT
60 80 10 38 a5 64 40 00 00:52:06.640 READ FPDMA QUEUED
Error 955 occurred at disk power-on lifetime: 13972 hours (582 days + 4 hours)
84 51 41 87 9d 58 02 Error: ICRC, ABRT at LBA = 0x02589d87 = 39361927
60 80 08 30 a4 64 40 00 00:52:06.640 READ FPDMA QUEUED
60 80 00 48 9d 58 40 00 00:52:06.639 READ FPDMA QUEUED
ea 00 00 00 00 00 00 00 00:52:03.618 FLUSH CACHE EXT
61 08 00 88 87 e0 40 00 00:52:03.617 WRITE FPDMA QUEUED
Error 954 occurred at disk power-on lifetime: 13972 hours (582 days + 4 hours)
84 51 51 af 86 4c 02 Error: ICRC, ABRT at LBA = 0x024c86af = 38569647
60 80 10 40 40 4f 40 00 00:52:02.876 READ FPDMA QUEUED
60 80 00 38 3f 4f 40 00 00:52:02.872 READ FPDMA QUEUED
60 80 08 80 86 4c 40 00 00:52:02.870 READ FPDMA QUEUED
60 80 10 68 84 4c 40 00 00:52:02.862 READ FPDMA QUEUED
60 80 00 a8 31 44 40 00 00:52:02.861 READ FPDMA QUEUED
# 1 Short offline Completed without error 00% 13990 -
# 2 Short offline Completed without error 00% 13989 -
# 3 Short offline Completed without error 00% 13988 -
# 4 Short offline Completed without error 00% 13987 -
# 5 Short offline Completed without error 00% 13986 -
# 6 Short offline Completed without error 00% 13985 -
# 7 Short offline Completed without error 00% 13984 -
# 8 Short offline Completed without error 00% 13983 -
# 9 Short offline Completed without error 00% 13982 -
#10 Short offline Completed without error 00% 13981 -
#11 Short offline Completed without error 00% 13980 -
#12 Short offline Completed without error 00% 13979 -
#13 Short offline Completed without error 00% 13978 -
#14 Short offline Completed without error 00% 13977 -
#15 Short offline Completed without error 00% 13976 -
#16 Short offline Completed without error 00% 13975 -
#17 Short offline Completed without error 00% 13974 -
#18 Short offline Completed without error 00% 13973 -
#19 Short offline Completed without error 00% 13973 -
#20 Short offline Completed without error 00% 13972 -
#21 Short offline Completed without error 00% 13971 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@freenas] ~#
It shouldn't... not sure why that is happening, but maybe camcontrol errors are preventing normal FreeNAS operation somehow.
These 870 errors are where it's at...
CRC errors could indicate some kind of connectivity, but SMART data is gathered onboard the disk itself, so should exclude any cabling issues.
You can have a look at your cabling to that disk, but I think it's not going to survive the fight.
EDIT: a quick bit of googling showed that this may be errors detected by the disk, but in its communication with the controller, so could be a cable problem... definitely check your cables.
crusader27529
I know da1 isn't perfect, but since I can't manage the volumes with the GUI, can you give me a set of commands that I can use instead of the GUI to essentially do what the GUI does?
Specifically, zpool commands to take drives offline and to resilver the replacement?
Any other useful commands to monitor and manage the system would be great........I've wanted to learn the command line to do these type functions anyway.
We really shouldn't go off piste here unti we've stopped the CRC errors... perhaps these are the root cause and solving them will bring everything back.
You can find a lot of information on the zpool commands like offline, online, replace and many more, but FreeNAS is at its best when you don't use those. The middleware does a lot of additional checking in the background to keep things simple and clean that can be missed when running commands manually.
crusader27529
OK, I'll order a replacement for da1.......................I doubt that it'll help with the GUI issue, but I'll do it anyway.
I meant you should check the cabling.
