No Tree View, and Plugins: Couldn't retreive status -
ulf
Have installed FreeNAS-8.3.1-RELEASE-p2-x64 on a machine, and had everything working.
Jail was set to IP=10.175.196.100 with the router beeing 10.175.196.1
Then I moved the machine to another network, which has the same router IP=10.175.196.1
DHCP allocated a different address in the 10.175.196.XX range. (10.175.196.24)
In this network, IP=10.175.196.100 was allocated to another machine,so the jail didn't work.
I reconfigured the router, freeing up IP=10.175.196.100, and then DLNA started working,
and the CIFS export as well.
One problem is that the Tree View to the left is missing/empty and the GUI cannot be used to change
things like the Jail IP.
Now, I had a power outage, and after that the CIFS shares are no longer present.
All my Three plugins, transmission, firefly and minidlna seems to run.
I can ping 10.175.196.100 as well.
I see error messages in the shell: manage.py similar to:
"Couldn't retreive http://10.175.196.24/plugins/firefly/_s/status"
HTTP Error 502: Bad Gateway
Have a green light on the upper right corner in the GUI.
I expect not getting the tree view is the core of my problems.
Just get the links "expand all" "collapse all" and then below, an empty box.
(See attached picture)
Any clues on this?
ulf
OK, Not getting the tree view, was due to me using Internet Explorer 10.
I get the tree view in Firefox.
The Configuration for the Plugins was missing, and I reinstalled them, and now I can configure them,
but still not visible as a CIFS share :-(
ulf
Noticed that hostname was "nas.local" and changed this back to "freenas"
to corrspond to the NETBIOS name, but still no progress.
Strange, since I have not changed this...
ulf
Strange, Windows does not find the FreeNAS share when I search in Explorer,
but if I type "\\FreeNAS" in the address field, I can access the machine...
