No such file or directory: '/dev/ada1'
afmayer
I have successfully pooled two 1TB 2.5"drives, but my 6TB drives will not pool.
Tried several times, no luck.
  • Motherboard make and model
    • ASRock A75 EXTREME6 FM1 AMD A75 (Hudson D3) SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard with UEFI BIOS
      AMD Entertainment Edition 4GB 240-Pin DDR3 SDRAM DDR3 1333 Desktop Memory Model AE34G1339U2-U x 4 (16GB)
  • CPU make and model
    • AMD A6-3650 APU with Radeon HD Graphics, 2.6GHz, 16GB RAM None Network Attached Storage 2011 AMD A6-3650 Llano Quad-Core 2.6 GHz Socket FM1 100W AD3650WNGXBOX Desktop APU (CPU + GPU) with DirectX 11
  • RAM quantity
    • 16GB
  • Disks Boot disk
  • 107 SSD
    ada0
    9XG2JL2X
    931.51 GiB
    Mirror1TB
    ada1
    32W0A0PFFR1H Toshiba N300 NAS 7200rpm, 256MB buffer
    5.46 TiB
    N/A
    ada2
    OCZ-6308VGDAEF9PD634
    107.13 GiB
    boot-pool
    ada3
    32J0A0L2FR1H Toshiba N300 NAS 7200rpm, 256MB buffer
    5.46 TiB
    N/A
afmayer
  • RAM quantity
    • 16GB
  • Disks Boot disk
  • 107 SSD
    ada0
    9XG2JL2X
    931.51 GiB
    Mirror1TB
    ada1
    5.46 TiB
    N/A
    ada2
    107.13 GiB
    boot-pool
    ada3
    5.46 TiB
    N/A
  • troubleshoot2.txt
Samuel Tai
Make sure your 6TB drives don't have any partitions on them. What does gpart show ada1 and gpart show ada3 show? If any partitions are shown, then run gpart destroy -F ada1 and likewise for ada3.
afmayer
Where do I type in "gpart destroy -F ada1"
afmayer
I seated the data cable a couple times b/c one drive was intermittently disappearing from the DISK list.
I got it to work and pool with the other same exact drive.
Now what? How do I setup using them (dump data onto them).
afmayer
I found a video about the datasets.
BUT, TrueNAS has degraded one of the two pooled drives (in both pools), so I unplugged all the drives, reseated them, and reinstalled TrueNAS. I destroyed the partitions and will try again.
afmayer
...Reinstalled TrueNAS, formatting the boot disk, a 107GB SSD.
On reboot, system is stuck at uhub7:<AMD OHCI root HUB, class 9/0, rev 3.00/1.00, addr1> on usbus3
I still have the monitor, mouse, and keyboard attached.
afmayer
Reloaded, changed cables around... maybe one 3wasn't working BUT now the system is up. 6TB pooled fine, but one of the 1TB did not. Tried deleting with Shell commands (above), but only worked when wiped via one of the Storage screens.
Question I have is, "Can I attach ONE HDD just to have it online (not pooled or striped).
