nightly crash, need help debugging
ykhodo
I have an install of FreeNAS that I set up last week. I am getting the nightly emails, but then when I wake up the AM, the machine refuses to accept connections, and there is nothing coming from the monitor. The machine has power and is still physically up.
The last things from /var/log/messages are the following:
Oct 23 03:00:14 hadrian kernel: arp: <redacted> moved from <redacted> on igb0
Oct 23 03:02:25 hadrian kernel: arp: <redacted> moved from <redacted> on igb0
There is nothing in /data/crash.
What would be the best way to debug this issue?
Thanks!
ykhodo
Post your hardware specs and the output of ifconfig.
ryzen 1700x
asrock x370 taichi
wd red 4 x 4tb
wd red 2 x 5tb
intel 128gb ssd for the host (it's about 5 years old but at 97% health)
600w corsair psu
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6>
	ether <redacted>
	inet <redacted> netmask 0xffffff00 broadcast <redacted>
	media: Ethernet autoselect (1000baseT <full-duplex>)
	status: active
	options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
	inet6 ::1 prefixlen 128
	inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
	groups: lo
	ether <redacted>
	nd6 options=1<PERFORMNUD>
	groups: bridge
	member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 9 priority 128 path cost 2000000
	member: epair4a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 8 priority 128 path cost 2000
	member: epair3a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 7 priority 128 path cost 2000
	member: epair2a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 6 priority 128 path cost 2000
	member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 5 priority 128 path cost 2000
	member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 4 priority 128 path cost 2000
	member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 1 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=8<VLAN_MTU>
	ether <redacted>
	status: active
	groups: epair
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=8<VLAN_MTU>
	ether <redacted>
	status: active
	groups: epair
epair2a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=8<VLAN_MTU>
	ether <redacted>
	status: active
	groups: epair
epair3a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=8<VLAN_MTU>
	ether <redacted>
	status: active
	groups: epair
epair4a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=8<VLAN_MTU>
	ether <redacted>
	status: active
	groups: epair
tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=80000<LINKSTATE>
	ether <redacted>
	status: active
	groups: tap
	Opened by PID 11584
ykhodo
I'll so add that I am running 4 jails - plex, transmission, couchpotato, and sickrage.
You can see the crash is happening at around 3:05.
D
dlavigne
Guest
Anything in /var/log/messages prior to the crash? Also, how much RAM on the system?
D
dlavigne
Guest
If it is, it should be resolved by BETA1 (or 11.1 if you prefer to wait for RELEASE).
ykhodo
Disabling just c6 or global c-state did not fix my problem. With both disabled in the bios, I have been up for 3 days with no crashes.
wackymole
It now appears to be random when it crashes. I was getting 5 days now it crashed within 2 days. I doubt it has anything to do with SMT because it happening usually in the middle of the night. I did not test for long term stability with my 11.0 build, but I don't remember anything like this happening. I will see what happens in 11.1, but I might have to change my freenas Ryzen recommendation to not stable. Keep up the great job on the bugs/roadmap!~Eventually
wblock
Documentation Engineer
Does that platform actually enable ECC, or just allow the use of ECC RAM while ignoring the important error-correcting abilities?
Nightly reports cause a fair amount of disk activity. How old is that power supply, and of what quality?
