Hello there. I hope you can eventually help me solve my problem.
I have a multihomed Freenas Server, generic hardware (FreeNAS-9.10.1-U2 (f045a8b)) with two links aggregates connected to different VLANS.
I want to share a dataset with NFS for ESX servers to make some ISOs available, on one of the interfaces.
The network setting is as follow :
The ESX servers are on the 192.168.0.0/24 network. From them, I have no problem reaching the Freenas server, I can ping and ssh, no problem.
Problem : NFS is not reachable on the lagg1 interface. If I try to mount the share, it fails everytime.
This setup worked with the 9.2 and 9.3 versions !
A showmount, from another client on the same network shows :
If I check with nmap :
Port 111 (rpcbind) is not open.
However, if I check the other address :
A wild rpcbind appears...
And on this address, NFS works with no problem.
check on the Freenas server :
It does not listen on lagg1 with tcp4.
If I look for the process :
I tried to check/uncheck both addresses in the gui, stoppping/restarting the service, to no avail, I can't make the "-h 10.117.72.14" go away.
I'm sure it worked with Freenas 9.2. I have another server, FreeNAS-9.2.1.9-RELEASE-x64 (2bbba09), where it works as expected : unchecking all the interfaces, rpcbind has no argument. Checking both, it gets two "-h" options.
How can I make it so that rpcbind gets no argument?
In a normal FreeBSD system, I'd just edit /etc/rc.conf, but here, I don't know.
I don't even know why it selects this interface.
lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=9b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM> ether 00:30:48:d5:17:d1 inet 10.117.72.14 netmask 0xfffffc00 broadcast 10.117.75.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: active laggproto lacp lagghash l2,l3,l4 laggport: em1 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> laggport: em2 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> lagg1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=9b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM> ether 00:30:48:d5:17:d0 inet 192.168.0.11 netmask 0xffffff00 broadcast 192.168.0.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: active laggproto lacp lagghash l2,l3,l4 laggport: em0 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> laggport: em3 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
# showmount -e 192.168.0.11 showmount: 192.168.0.11: RPC: Rpcbind failure - RPC: Unable to receive
# nmap 192.168.0.11 Host is up (0.00033s latency). Not shown: 995 closed ports PORT STATE SERVICE 22/tcp open ssh 80/tcp open http 139/tcp open netbios-ssn 445/tcp open microsoft-ds 2049/tcp open nfs
# nmap 10.117.72.14 Host is up (0.00033s latency). Not shown: 994 closed ports PORT STATE SERVICE 22/tcp open ssh 80/tcp open http 111/tcp open rpcbind 139/tcp open netbios-ssn 445/tcp open microsoft-ds 2049/tcp open nfs
# netstat -na | grep 111 tcp4 0 0 10.117.72.14.111 *.* LISTEN tcp4 0 0 127.0.0.1.111 *.* LISTEN tcp6 0 0 ::1.111 *.* LISTEN
# ps -aufx | grep rpcbind root 93112 0.0 0.0 29160 2588 - Is 11:07AM 0:00.01 /usr/sbin/rpcbind -h 10.117.72.14
