I have an NFS share I use for persistant storage of rancherOS (docker) and I have two nodes running rancherOS that I want to mount this share. One node is a VM (created with the FreeNAS GUI by choosing a docker VM) and one node is a separate machine with rancherOS running bare metal.
IP's, hostnames and FQDN:
FreeNAS: 192.168.1.1 - data - data.ad.tld
rancherOS1 (VM) 192.168.1.2 - docker docker.ad.tld
rancherOS 2 (Bare) 192.168.1.4 - docker2 docker.ad.tld
I can ping every machine from every other machine by ip, hostname and FQDN.
The problem is that only the first (VM) machine is able to mount an NFS share from FreeNAS, the other machine gives a timeout. Both machines should have access according to the share settings.
Am I missing something? See the freenas-debug -N output below:
# freenas-debug -N
+					FreeNAS-11.2-RC1 (c831a6a98) @							  +
Operating system type: FreeBSD
Operating system release: 11.2-STABLE
Operating system revision: 199506
Kernel version: FreeBSD 11.2-STABLE #0 r325575+97f4f541349(freenas/11.2-stable): Wed Oct 17 18:06:49 EDT 2018
   root@nemesis.tn.ixsystems.com:/freenas-11.2-releng/freenas/_BE/objs/freenas-11.2-releng/freenas/_BE/os/sys/FreeNAS.amd64
Hostname: data.ad.x.tld
Name of kernel file booted: /boot/kernel/kernel
debug finished in 0 seconds for FreeNAS-11.2-RC1 (c831a6a98)
+						  NFS Boot Status @									 +
NFS will start on boot.
debug finished in 0 seconds for NFS Boot Status
+						   NFS Run Status @									 +
nfsd is running as pid 2165 2166.
debug finished in 0 seconds for NFS Run Status
+							 /etc/hosts @									   +
::1					 localhost localhost.my.domain
127.0.0.1			   localhost localhost.my.domain
192.168.1.2 docker.ad.x.tld docker
192.168.1.4 docker2.ad.x.tld docker2
127.0.0.1	   data.ad.x.tld data
::1			 data.ad.x.tld data
debug finished in 0 seconds for /etc/hosts
+							/etc/exports @									  +
V4: / -sec=sys
/mnt/Storage/VM/docker -alldirs -mapall="root":"wheel"
debug finished in 0 seconds for /etc/exports
+							showmount -e @									  +
Exports list on localhost:
/mnt/Storage/VM/docker			 Everyone
debug finished in 0 seconds for showmount -e
+							 rpcinfo -p @									   +
   program vers proto   port  service
   100000	4   tcp	111  rpcbind
   100000	3   tcp	111  rpcbind
   100000	2   tcp	111  rpcbind
   100000	4   udp	111  rpcbind
   100000	3   udp	111  rpcbind
   100000	2   udp	111  rpcbind
   100000	4 local	111  rpcbind
   100000	3 local	111  rpcbind
   100000	2 local	111  rpcbind
   100005	1   udp	863  mountd
   100005	3   udp	863  mountd
   100005	1   tcp	863  mountd
   100005	3   tcp	863  mountd
   100003	2   tcp   2049  nfs
   100003	3   tcp   2049  nfs
   100024	1   udp	990  status
   100024	1   tcp	990  status
   100021	0   udp	928  nlockmgr
   100021	0   tcp	601  nlockmgr
   100021	1   udp	928  nlockmgr
   100021	1   tcp	601  nlockmgr
   100021	3   udp	928  nlockmgr
   100021	3   tcp	601  nlockmgr
   100021	4   udp	928  nlockmgr
   100021	4   tcp	601  nlockmgr
debug finished in 0 seconds for rpcinfo -p
+							  nfsstat @										 +
Client Info:
Rpc Counts:
  Getattr   Setattr	Lookup  Readlink	  Read	 Write	Create	Remove
	   0		 0		 0		 0		 0		 0		 0		 0
   Rename	  Link   Symlink	 Mkdir	 Rmdir   Readdir  RdirPlus	Access
	   0		 0		 0		 0		 0		 0		 0		 0
   Mknod	Fsstat	Fsinfo  PathConf	Commit
	   0		 0		 0		 0		 0
Rpc Info:
 TimedOut   Invalid X Replies   Retries  Requests
	   0		 0		 0		 0		 0
Cache Info:
Attr Hits	Misses Lkup Hits	Misses BioR Hits	Misses BioW Hits	Misses
	   0		 0		 0		 0		 0		 0		 0		 0
BioRLHits	Misses BioD Hits	Misses DirE Hits	Misses Accs Hits	Misses
	   0		 0		 0		 0		 0		 0		 0		 0
Server Info:
   23342	  9931	   407		 7	   126	   345		 9		11
	   8		 0		 0		 0		 0	  1381		 0	  5406
	   0		 0		 2		 1		 5
Server Ret-Failed
			   0
Server Faults
		   0
Server Cache Stats:
   Inprog	  Idem  Non-idem	Misses
	   0		 0		 0	 25160
Server Write Gathering:
 WriteOps  WriteRPC   Opsaved
	 345	   345		 0
debug finished in 0 seconds for nfsstat
+							 nfsstat -c @									   +
Client Info:
Rpc Counts:
	   0		 0		 0		 0		 0		 0		 0		 0
	   0		 0		 0		 0		 0		 0		 0		 0
	   0		 0		 0		 0		 0
Rpc Info:
	   0		 0		 0		 0		 0
Cache Info:
	   0		 0		 0		 0		 0		 0		 0		 0
	   0		 0		 0		 0		 0		 0		 0		 0
debug finished in 0 seconds for nfsstat -c
+							 nfsstat -s @									   +
Server Info:
	   0		 0		 2		 1		 5
Server Ret-Failed
			   0
Server Faults
		   0
Server Cache Stats:
	   0		 0		 0	 25160
	 345	   345		 0
debug finished in 0 seconds for nfsstat -s
+					 nfsv4 locks: nfsdumpstate @								+
Flags		 OpenOwner	  Open LockOwner	  Lock	 Deleg  OldDeleg Clientaddr	  ClientID
					 4		11		 0		 0		 0		 0 192.168.1.2	 4c696e7578204e465376342e30203139322e3136382e312e322f3139322e3136382e312e3120746370
debug finished in 0 seconds for nfsv4 locks: nfsdumpstate
