nextcloud trusted domains
OmriA
Hi, I want to add a trusted domain to my next cloud app.
*I'm very new at this*
I tried every guide and every form and nothing works.
I'll try to add all the information I can.
As you can see I can find the file in the SMB shares, but I can't open/copy/edit it at all
I tried with shell but no guide worked.
Kasen
Hi, have you solved this problem? Would you please share some ideas?
VD_BE
pkg install nano
cd /usr/local/www/nextcloud/config/
cp config.php config.php-backup
nano config.php
Add this
2 => '192.168.0.0', #trusted IP
3 => 'nextcloud.domain.com', #trusted doamin
ctrl+s - save
ctrl+x - exit
cd /usr/local/etc/nginx/conf.d/
cp nextcloud.conf nextcloud.conf-backup
nano nextcloud.conf
Add this
server
listen 80;
server_name nextcloud.domain.com;
VD_BE
You are also in the wrong shell, you need to go to the jail of your nextcloud and the shell there
victort
Correct. Jails are a CORE thing, not a SCALE thing.
What I like to do is mount the app data outside the app, then edit the config.php file which will then be stored outside in whatever dataset you have configured it to use.
Kasen
Hi, I SMB share the nextcloud app folder to windows and edit it.
but still failed. I reinstall the truenas scale. I dont know what I changed it. The first time to use truenas. Try it later.
Thank you!
