I saw your response and I combined with another of your reply on another thread to replace 'occ' with su -m www -c 'php /usr/local/www/nextcloud/occ something.. but I am not able to cancel the update. Stuck in 'update in progress' on truenas jail. What should be the path and command for freebsd jail?
If this doesn't work, you can recover your previous instance of Nextcloud. You need to find the backup location Nextcloud has created, most likely under a Backup folder within your Nextcloud dataset.
