Nextcloud questions
Alvita
(English is not my native langage, i'm trying to be as clear as possible :smile: )
I've just set up locally (for now) a jail with nextcloud thanks to this great tutorial : Samuel Downling's tutorial .
So this is an nexcloud installation on Apache 2.4 using php-fpm. I'm a newbie to freenas and unix system.
I've 1TB of data that i've recover from an XPenology installation, and i want to transfer this data on my fresh Nextcloud install.
I'm transfering all of the data (music, video..) via WebDAV and the WebUI of Nextcloud and i'm facing a problem :
- I can't upload more than 6 - 9 gb of data at once, i got the well known "Error when assembling chunks, status code 504". I've done a couple of thing for that, according to the Nexcloud documentation. Even when this error occurs, i can have acces to my files after approx. 5 minutes or less.
In php.ini file :
-> upload_max_filesize 20G
-> post_max_size 20G
-> max_input_time 3600
-> max_execution_time 3600
-> memory_limit 2G
In www.conf :
request_terminate_timeout=173h
I'm assuming this is a limitation of php or apache. Or this could be a ram issue ?
I tought it might be possible to transfer the data in another way.
How can i merge all the data on my external hard drive, to Nexcloud storage, without using WebDAV or the WebUI ?
How can i make a shared folder where nextcloud can Read and Write, and freenas Read Only to share this folder over NFS ?
Awaiting your precious answers,
Thank you in advance.
Alvita.
Alvita
I've forgot to mention my specs!
CPU : Intel Xeon E3 1220 v6
RAM : 2400Mhz ECC
(i think this is all that matter?)
Update : i've just uploaded successfully a 20 GB without a problem...
quangpham
RAM : 2400Mhz ECC
Hi Alvita,
Pls show me how to fix it?
adrianwi
What are you using as a database?
