Nextcloud max file size setting on TrueNAS SCALE
monkey23
Hi everyone,
I'm currently running a homelab with TrueNAS SCALE 22.12.3.1 and NextCloud 27.0.0_1.6.31 app installed.
I did the following steps to increase the file size limit of NextCloud from 512M to 16G,
1. get access to the shell of NextCloud container,
docker exec --user root -it NEXTCLOUD-CONTAINER-ID /bin/sh
2. install nano editor,
apt update
apt install nano
3. go to php directory
cd /usr/local/etc/php
There are two ini files in the directory: php.ini-development and php.ini-production
4. I changed the following configurations of the php.ini-production file
nano php.ini-production
upload_max_filesize = 16G
post_max_size = 16G
max_input_time = 3600
max_execution_time = 3600
and then save.
But after I restart the NextCloud app in TrueNAS, I found that all changes to the container are not saved.
Since I'm not so familiar with k8s, I really appreciate your instructions on how to do this correctly.
Thanks in advance!
You shouldn't be making changes to the container... set your persistent storage options so that the config is on your NAS host instead of in the container, then changes will remain when the container is redeployed (which happens almost every time you stop or start it in kubernetes).
Lepelot
Can you guys please explain how you locate and modify the php.ini file to increase the file size? I am using the nextcloud app on truenas scale.
Thank you
minotauras
You need to create php.ini. here is what I did to overcome this file limitation:
cp /usr/local/etc/php.ini-production /usr/local/etc/php.ini
nano /usr/local/etc/php.ini
modify these settings:
upload_max_filesize = 2G
post_max_size = 2G
Lepelot
OK, this sounds great, but I don't see this file when I log into the TrueNas shell. Is there another way to get to this file?
minotauras
run these commands to find if you have php installed and where php.ini file(s) might be:
whereis php
find / -name php.ini* 2>/dev/null
