nextcloud + lets encrypt missing
phier
hi,
any idea why there is no option/description how to enable Lets encrypt for nextcloud plugin?
thanks
phier
Any guess I might make wouldn't be very kind to iX, so I'll just say that my script handles Let's Encrypt automatically:
thats nice but its another "fork" from official stuff ;///
The "official stuff" in terms of plugins is deprecated, so I don't see much (read: any) value in trying to stick with it. But, naturally, you should do what seems best to you.
phier
ah okay ;/ thanks
your script looks great, i mean the way how the environment of nextcloud is set up etc... but its also not up to date, isnt it?
I haven't updated the script to default to Nextcloud 24, but I have tested it, and it works fine. Just set NEXTCLOUD_VERSION=24 in the config file and it will install that version. Everything else is installed from the FreeBSD packages, which are pretty up-to-date. And keeping it up-to-date can be done through the built-in Nextcloud updater and/or the FreeBSD package system.
phier
so it failed... ;/
nextcloud-config
NEXTCLOUD_VERSION="24.0.3"
go: downloading github.com/golang/groupcache v0.0.0-20210331224755-41bb18bfe9da
2022/08/02 19:38:38 [INFO] exec (timeout=0s): /usr/local/bin/go build -o /usr/local/bin/caddy -ldflags -w -s -trimpath
2022/08/02 19:40:37 [INFO] Build complete: /usr/local/bin/caddy
2022/08/02 19:40:37 [INFO] Cleaning up temporary folder: /tmp/buildenv_2022-08-02-1936.907415802
fetch: https://download.nextcloud.com/server/releases/latest-24.0.3.tar.bz2: Not Found
fetch: https://download.nextcloud.com/server/releases/latest-24.0.3.tar.bz2.asc: Not Found
/tmp/nextcloud.asc                                    3100  B   19 MBps    00s
Command: fetch -o /tmp https://download.nextcloud.com/server/releases/latest-24.0.3.tar.bz2 https://download.nextcloud.com/server/releases/latest-24.0.3.tar.bz2.asc https://nextcloud.com/nextcloud.asc failed!
Failed to download Nextcloud
Script done, output file is nextcloud.log
now question would be... do i have to kill (remove) jail and start again?
Yes.
Look at my earlier post again--I said NEXTCLOUD_VERSION="24". Just specify the major version; the script automatically downloads the latest minor release in that.
phier
so i completely removed the jail ... and executed the command from the scratch .. but still cant access it :(
and i am using duckdns.org instead of Cloudflare...
and when i try access it from local ip it says >
phier
yes fixed but still cant access it :(
thats what i was saying undocumented and now who can fix the stuff... nooeone as noone has any idea whats and how is setup there...
and the /var/log/domainname file is full of records as ...
{"level":"info","ts":1659468624.9242651,"logger":"http.log.access.log0","msg":"handled request","request":{"remote_ip":"193.37.33.11","remote_port":"11073","proto":"HTTP/1.1","method":"GET","host":"xxxx1.duckdns.org","uri":"/","headers":{"User-Agent":["python-requests/2.22.0"],"Accept-Encoding":["gzip, deflate"],"Accept":["*/*"],"Connection":["keep-alive"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","server_name":"xxx.duckdns.org"}},"user_id":"","duration":0.022436067,"size":0,"status":302,"resp_headers":{"Content-Security-Policy":["default-src 'self'; script-src 'self' 'nonce-RG5CUGExL2xtZ1NHOTBscDM1MEdsQ3lvNTBlcUdJemZmd0tURE1EdUM3UT06UmlNRFVoaUozVkRWd240UnZPaEl4QjNkc0RQTlcveW5Na3pXZVpIQmJmWT0='; style-src 'self' 'unsafe-inline'; frame-src *; img-src * data: blob:; font-src 'self' data:; media-src *; connect-src *; object-src 'none'; base-uri 'self';"],"X-Content-Type-Options":["nosniff"],"X-Robots-Tag":["none"],"X-Frame-Options":["SAMEORIGIN"],"Location":["https://xxx1.duckdns.org/login"],"Content-Type":["text/html; charset=UTF-8"],"Cache-Control":["no-store, no-cache, must-revalidate"],"X-Permitted-Cross-Domain-Policies":["none"],"Referrer-Policy":["no-referrer"],"X-Xss-Protection":["1; mode=block"],"Status":["302 Found"],"Expires":["Thu, 19 Nov 1981 08:52:00 GMT"],"Set-Cookie":[],"Server":["Caddy"],"X-Powered-By":["PHP/8.0.20"],"Pragma":["no-cache"]}}
{"level":"info","ts":1659468625.2010803,"logger":"http.log.access.log0","msg":"handled request","request":{"remote_ip":"193.37.33.11","remote_port":"11073","proto":"HTTP/1.1","method":"GET","host":"xxxx1.duckdns.org","uri":"/login","headers":{"User-Agent":["python-requests/2.22.0"],"Accept-Encoding":["gzip, deflate"],"Accept":["*/*"],"Connection":["keep-alive"],"Cookie":[]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","server_name":"xxx.duckdns.org"}},"user_id":"","duration":0.030864936,"size":4258,"status":200,"resp_headers":{"Content-Security-Policy":["default-src 'none';base-uri 'none';manifest-src 'self';script-src 'self';style-src 'self' 'unsafe-inline';img-src 'self' data: blob:;font-src 'self' data:;connect-src 'self';media-src 'self';frame-src 'self';frame-ancestors 'self';worker-src 'self' blob:;form-action 'self'"],"Server":["Caddy"],"Content-Type":["text/html; charset=UTF-8"],"X-Frame-Options":["SAMEORIGIN"],"Cache-Control":["no-cache, no-store, must-revalidate"],"X-Request-Id":["NIvBZt0OLv5FM5graEQW"],"X-Powered-By":["PHP/8.0.20"],"Referrer-Policy":["no-referrer"],"Pragma":["no-cache"],"Expires":["Thu, 19 Nov 1981 08:52:00 GMT"],"X-Permitted-Cross-Domain-Policies":["none"],"Content-Encoding":["gzip"],"Feature-Policy":["autoplay 'self';camera 'none';fullscreen 'self';geolocation 'none';microphone 'none';payment 'none'"],"Content-Length":["4258"],"X-Xss-Protection":["1; mode=block"],"X-Content-Type-Options":["nosniff"],"X-Robots-Tag":["none"]}}
caddy log
{"level":"info","ts":1659468792.4528084,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"xxxx.duckdns.org"}
{"level":"info","ts":1659468792.452817,"logger":"tls.obtain","msg":"releasing lock","identifier":"xxxx.duckdns.org"}
phier
like all the projects without proper documentation - doomed.
maybe the issue is that the nextcloud is running behind 2 NATs? Ie 1. nat on the provider router; 2. nat on my openwrt router... then nextcloud jail
have no clue
Patrick M. Hausen
This is free community driven open source software - the Nextcloud script by Dan. It is assumed that whoever uses it has got some basic system administration skills and experience running Unix systems. Possibly you are better off just renting a Nextcloud full service.
1 TB of fully managed Nextcloud storage can be had for less than 5 €/$ per month:
Also you are free to buy professional services like with any other complex IT product. Nextcloud itself is at least as complex as your entire TrueNAS operating system.
There's a support thread for that script, and it's linked in the GitHub repo. This isn't it. There's also pretty thorough documentation. I'm happy to address deficiencies if they're identified, but a drive-by line like this makes you look like a smart*ss, and doesn't do much to motivate me to help you. One of the things that documentation says is that you shouldn't expect access via IP address to work. Another of the things it says is that your hostname needs to resolve to the local IP of your jail from inside your network. I'd expect one or the other, or both, of these is responsible for the issues you're seeing.
phier
yes i checked ppl mentioned similar issues but no fix was mentioned... ;/
yes thats correct and it doesnt work.
this part i dont get...
how can you resolve public hostname to the local ip?
i dont know if issue is because the jail is behind 2 NATs ... no clue.
