We had a power outage and the freenas server updated to. No our next cloud is hosed and cant run (says running but can not access it. just says rejecting connections)
Tried to install a new version, This always fails with "Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [1045] Access denied for user 'dbadmin'@'localhost' (using password: YES)" Even installed a fresh TrueNas on a separate server and have the same issues. I have tried everything ive found for the last 2 days on this and literally NOTHING, None of it WORKS to resolve the issue.
Even though its listed in the apps, I suspect Truenas is dropping support for NextCloud??.
How the hell do I get this installed or do we just move over to Unraid or something other than Truenas now?
