nextcloud and traefik using wrong certificate
dxmone
Hi, i am new to truenas scale but i am trying to setup nextcloud on a custom domain. Using cloudfare SSL. I have added the certificate and i have setup Traefik. And deployed nextcloud. The app works fine but I can't get traefik to use the cert it's using the default certificate.
In the nextcloud app i have this configuration. I am thinging this is where i am doing it wrong. I tried to select the cert using the dropdown but it was labled depricated and i can't find any information what clusterissuer is, is it the cloudflare, cert or something else?
I think it's a small problem to fix but i can't find any information that helps me on the forum/google.
Here is a screenshot of traefik also.
Krennex
When I ran into this issue and found your post, I got excited to see someone describe my problem so accurately.
It was sorely disappointing to scroll down and see no replies.
So once I solved it, I created an account here just to answer you.
In my case, I had to go to my Domain Registrar and change SSL Encryption Mode to "Full". It was "Flexible" by default.
dxmone
Perfect, it worked when I changed to full:)
truecharts
This is indeed the issue.
For this reason, we would advice to always test apps locally before adding things like cloudflare or exposing from the internet.
If you need any help with TrueCharts, please reach out to out support staff on discord directly be filing a support ticket there.
We, sadly enough, do not have the capacity to also provide support on this forum as well.
lzhen
Damn, happen to me. not recovered after change into full. Do I need to delete the app and re-deploy it?
