Newer FreeBSD version for package zzlib when doing pkg upgrade in jail
Dwarf Cavendish
I haven't maintained my jails in a little while and I thought I'd pop in and upgrade them again. But alas, pkg upgrade tells me "newer version Newer FreeBSD version for package zzlib", "package 1203000" and "kernel 1202000" (apologies for not copy/pasting the output: copying from the console is not working for me).
I tried if upgrading my jail helped (to the latest, 12.2-RELEASE-p15), but it didn't. The version that I'm running is TrueNAS-12.0-U8.1.
I want to fix some vulnerabilities in my jail by updating. How should I proceed now?
Patrick M. Hausen
Upgrade your jail to FreeBSD 12.3. 12.2 is EOL.
Better yet, upgrade your TrueNAS to 13 and your jail to 13.1.
Dwarf Cavendish
...yeah, I figured that out myself by now, that TrueNAS 13 is out now. I'm usually prompted to do upgrades by emails that I get from my server, but it doesn't do that when a new train is available. Well, looks like I have some upgrading to do then...
Dwarf Cavendish
Just checking: it appears that the TrueNAS GUI isn't offering the possibility to upgrade to a new major release of FreeBSD. I wouldn't mind using iocage directly to do this, but I'd rather do it through the GUI if possible. Could I perhaps be overlooking something?
Patrick M. Hausen
Sorry, I always use iocage ...
The "way" to do that in the GUI is to delete your jail and make a new one.
If you're doing your jails right, it should just be a question of adding back the storage mounts and a little work with pkg to put the app back (if you're not using plugins), then make sure the user and UIDs match what you had before.
Upgrades of major versions take forever and always have that annoying set of prompts where you have to quit the readme 3 times to proceed, so you can't even go away and leave it to run.
Dwarf Cavendish
So I just discovered, I reckon it took 2 hours for a single jail to upgrade using iocage from a shell. Luckily I only have 2 of them :smile: .
You can reduce that time substantially by first deleting /usr/src in the jail (assuming you only use pkgs, not ports), but it's still an archaic process when compared to creating a new jail in a few minutes (let's say max 15 to do all the config).
Dwarf Cavendish
Believe it or not, but I'm just too lazy to recreate my jails and redo the config I did in them :wink: . I'll keep the cleaning out of /usr/src in mind for the next time, though!
