ornias
 - Mar 6, 2020
Some additional info on why Evert is right here:This is VERY overstated. ECC is recommended and I fully agree with that recommendation. But loosing all your data just because of the use of non ECC memory is nonsense.
It's important to notice the difference in articles between "dataloss" and "total pool failure". Most articles and statistics dealing with redundancy or ECC are talking about dataloss, this can mean a whole drive, whole pool or (most often) even a single block.
The chance of non-ecc corrupting a single block is very small, as long as your ram checks out, way smaller than dataloss due to disk failure. The chance of non-ecc corruption leading to a cascading failure that leads to a whole pool being lost... is even many times smaller than that.
Should you try to use ECC? Yes.
Is it required? No.
Please remember IX recomendations should always be read as: "Can you expect us or the forum to fully support you if you have issues due to not listening to us"
Please be aware that TrueNAS 12 RC is somewhat equal to the old FreeNAS Release versions. there is a translation sheet in another topic :)Depending on how important your system is to you I would wait for the release. On my production evironment no beta or RC's
Most issues with Beta and Release versions of FreeNAS always where updating old systems. If you start from scratch I think the curent BETA2 is relatively solid.
(Not saying you should use it already, just stating some info you should take into account).
Other comments:
- Your build is rock solid.
- Go Raidz2 or raidz3 for bulk archive storage, not striped mirrors and NOT raidz1.
- Be sure to set a nice high blocksize.
