I have a Silverstone Grandia GD07.
Looks like a standard HTPC enclosure, supports ATX motherboards and PSUs and if you ever get a rack then it also is 19" compatible.
A fractal node 804 would also fulfill your requirements. It's cheaper but only handles mATX mobos.
For CPU etc. you could get a low powered ryzen 5600(G) or similar and also turn on eco mode in the UEFI to get it to run cool with minimal fan speed. (But be aware that the G models do not support ECC).
As for the PSU beQuiet usually lives up to their name.
Hi
@asap2go and others.
So is the AMD Ryzen 5600G fully-supported under TN CORE or is SCALE needed for full support?
Sorry if this question seems out-of-touch, but it completely is because I have not been following TrueNAS development.  In fact, I'm still running end-of-life FreeNAS 11.3 on on old i3-2105 system that originally started with FreeNAS 8 from ages ago.  But that hardware is getting long in tooth so I'm going to be upgrading, and just snapped up a good deal on a Ryzen 5600G.
In my limited catching up over the last few hours, I am understanding that Intel is the preferred brand for TN CORE given its FreeBSD roots, but TN SCALE might work better for less selective hardware given its Linux roots.  I'd prefer to stay on CORE as it is the direct descendent of FreeNAS, but if the Ryzen 5600G has hiccups on CORE, I'll probably start with SCALE.
Anyway, I'll figure this out myself once all my new gear arrives, but if somebody can save me some testing time at this point, happy to hear it!
