New drive failed after a few days
serverboy
What firmware is on that HBA?
Is there a way to find this out within truenas or do i nees to press ctrl C on boot to go to the hba bios?
Ok, so i copied some files from the pool and a ton of those errors I posted above appeared in dmesg for DA11 the count for UDMA CRC Errors now went up to 51 on that drive i swapped around. The original FAULTED drive values have not been affected. Definitely something up with that slot. I will swap the cables round on that row with another row and see if it affects any drive there.
EDIT
Added the images
joeschmuck
Old Man
I want to make sure that you are aware, UDMA_CRC_Errors count will never go back to zero. It is recorded forever on the drive electronics. Don't ask anyone why that is, it would be nice to have the ability to reset it once the problem has been fixed but that is not the case. I'm only saying this to ensure that you know this fact and do not get upset later when you cannot return the count back to zero.
As for the HBA firmware, please note that I don't really keep up on this aspect of the forum as I do not use an LSI HBA, but I thought P20 vas the current version, not P16. Please do not take any action due to my comment, wait for someone who knows a lot more than I do on this topic give you advice. I can't say it this would be the problem for the UDMA_CRC_Errors either, I wouldn't think so but stranger things have happened.
Etorix
P20 is for LSI 2008 (PCIe 2.0); P16 is for LSI 3008 (PCIe 3.0). Firmware is not the issue here.
If the drive which has been moved to this slot now has CRC errors it is indeed a cable issue—except that the "cable" here consists of traces in the backplane.
serverboy
Thanks for the input everyone I really appreciate it.
So today I moved the cable from the 7-11 port on the HBA to port 0-3 and the problem followed to the drive on the end of the row DA03 when kicking of some transfers.
The bottom row of drives is empty at the moment so I moved the cable from slot 20-23 to the 7-11, booted it back up an kicked off some transfers.
On the console I kept a
tail -f /var/log/messages -n 1000
No errors appeared at all. So it looks like that cable is dodgy.
This is my first time dealing with SAS cables an HBAs. I would of thought if the cable was broke then all drives on that row would have been affected.
I am going to kick off a bad blocks run now on the whole server and see if anything comes from this.
Do these cables suffer from some sort of bend radius? Only thing I can think of is that the slight bend in the cable of damaged it somehow.
serverboy
What do you mean by traces?
serverboy
I know its a shame you can't wipe them but it is what it is I guess.
joeschmuck
Old Man
You can disregard that, you have isolated it to the data cable. Sometimes the backplane is the issue is what the reference was and given the available data at the time it was a viable option.
Yes, sometimes data cables just fail, without anyone touching them. You should replace it of course.
Yup
serverboy
You can disregard that, you have isolated it to the data cable. Sometimes the backplane is the issue is what the reference was.
Yup
I have ordered 2 more from Amazon, the ones I posted in my previous comments.
This has been a learning curve for me.
joeschmuck
Old Man
ChrisRJ
Most of us learn through the failures we encounter. Thankfully yours was an easy one.
"Good judgment comes from experience. And experience comes from bad judgement." Mark Horstman from Manager-Tools.com
serverboy
Hi Everyone
So after the long smart test ran. All drives reported back with no errors found. I copied some files off the share to my PC which was usually caused the errors to apper in the DMESG logs. Nothing has come up so far.
I am now running a scrub on the pool which is triggering a lot of email alerts.
Pool DATA01 state is ONLINE: One or more devices has experienced an
unrecoverable error. An attempt was made to correct the error. Applications
are unaffected.
The Scrub is currently at 10% but the pool has gone unhealthy now. But if i check the pool status all disks are online.
root@S-STORE01[~]# zpool status
  pool: DATA01
 state: ONLINE
status: One or more devices has experienced an unrecoverable error.  An
        attempt was made to correct the error.  Applications are unaffected.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
  scan: scrub in progress since Mon Sep 18 13:41:33 2023
        65.8T scanned at 22.5G/s, 8.01T issued at 2.74G/s, 65.8T total
        256K repaired, 12.16% done, 06:00:32 to go
        DATA01                                          ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/f01b9ed9-5258-11ee-abb2-7cc25504333c  ONLINE       0     0     0
            gptid/f04a29f8-5258-11ee-abb2-7cc25504333c  ONLINE       0     0     0
            gptid/f037c724-5258-11ee-abb2-7cc25504333c  ONLINE       0     0     0
            gptid/f08b59ed-5258-11ee-abb2-7cc25504333c  ONLINE       0     0     0
            gptid/f024fe29-5258-11ee-abb2-7cc25504333c  ONLINE       0     0     0
            gptid/f0a56333-5258-11ee-abb2-7cc25504333c  ONLINE       0     0     0
          raidz2-1                                      ONLINE       0     0     0
            gptid/efd1f769-5258-11ee-abb2-7cc25504333c  ONLINE       0     0     0
            gptid/f040d7ed-5258-11ee-abb2-7cc25504333c  ONLINE       0     0     0
            gptid/f02f2a10-5258-11ee-abb2-7cc25504333c  ONLINE       0     0     0
            gptid/f094735f-5258-11ee-abb2-7cc25504333c  ONLINE       0     0     0
            gptid/f08184cc-5258-11ee-abb2-7cc25504333c  ONLINE       0     0     0
            gptid/f09df0dd-5258-11ee-abb2-7cc25504333c  ONLINE       0     0     1  (repairing)
errors: No known data errors
  pool: NVME01
 state: ONLINE
        NAME                                          STATE     READ WRITE CKSUM
        NVME01                                        ONLINE       0     0     0
          gptid/ade1acfb-4504-11ee-a3bf-7cc25504333c  ONLINE       0     0     0
          gptid/ade44197-4504-11ee-a3bf-7cc25504333c  ONLINE       0     0     0
          gptid/ade02594-4504-11ee-a3bf-7cc25504333c  ONLINE       0     0     0
          gptid/ade67d57-4504-11ee-a3bf-7cc25504333c  ONLINE       0     0     0
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:00:06 with 0 errors on Thu Sep 14 03:45:06 2023
          mirror-0  ONLINE       0     0     0
            ada1p2  ONLINE       0     0     0
            ada0p2  ONLINE       0     0     0
root@S-STORE01[~]#
I believe that drive it states that it is repairing is the one which was having the CRC errors.
Am I right in thinking the pool is corrupted or is the scrub doing its thing it fixing it etc?
NugentS
is da11 a drive you were having issues with? That is reporting a chksum error.
Keep an eye on that - if it increases you still have a problem. Let the scrub complete and then have a look
serverboy
Yes that was the one.
Ok I will report back once it has finished. should be done later on this evening.
Can those errors be cleared or does it need to be rma'd?
serverboy
Hi @NugentS, it looks like the scrub has finished. The drive DA11 still shows the checksum error of 1 and the pool is still in a unhealthy state.
I have ran a short smart test on the da11 drive.
  pool: DATA01
 state: ONLINE
  scan: scrub repaired 256K in 07:11:56 with 0 errors on Mon Sep 18 20:53:29 2023
        DATA01                                          ONLINE       0     0     0
root@S-STORE01[~]# smartctl -a /dev/da11
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p7 amd64] (local build)
Device Model:     ST20000NM007D-3DJ103
Serial Number:    ZVT86SC8
LU WWN Device Id: 5 000c50 0e65d9382
Firmware Version: SN03
User Capacity:    20,000,588,955,648 bytes [20.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-4 (minor revision not indicated)
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Sep 18 21:15:54 2023 BST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  567) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        (1732) minutes.
Conveyance self-test routine
SCT capabilities:              (0x70bd) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   078   064   044    Pre-fail  Always       -       63999888
  3 Spin_Up_Time            0x0003   090   090   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       10
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   075   060   045    Pre-fail  Always       -       32477741
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       244
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       10
 18 Unknown_Attribute       0x000b   100   100   050    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   098   000    Old_age   Always       -       87
190 Airflow_Temperature_Cel 0x0022   060   045   000    Old_age   Always       -       40 (Min/Max 37/55)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       9
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       290
194 Temperature_Celsius     0x0022   040   055   000    Old_age   Always       -       40 (0 28 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   197   000    Old_age   Always       -       15479
200 Multi_Zone_Error_Rate   0x0023   100   100   001    Pre-fail  Always       -       0
240 Head_Flying_Hours       0x0000   100   100   000    Old_age   Offline      -       119 (145 117 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       12057994624
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       11981429584
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%       244         -
# 2  Extended offline    Completed without error       00%       216         -
# 3  Short offline       Completed without error       00%       189         -
# 4  Extended offline    Interrupted (host reset)      00%       187         -
# 5  Short offline       Completed without error       00%       174         -
# 6  Extended offline    Interrupted (host reset)      00%       174         -
# 7  Short offline       Completed without error       00%       160         -
root@S-STORE01[~]#
I ran a zpool clear DATA01 which has removed the value under checksum errors and restored the pool to a healthy state now.
joeschmuck
Old Man
I had said before to monitor the UDMA_CRC_Errors, maybe you forgot but they did increase in value, quite a bit actually.
serverboy
Hi
They increased as I was testing the drive when moving it around bays and doing some transfers. It hasn't moved since I fixed the cable issue.
I ran another scrub last night which completed successfully with no check sum errors.
No more messages have appeared in the logs like they did before. Unfortunately those values will stay on my drive now though. I do have 2 cold spares. But I am tempted to just RMA the drive to get a fresh one.
joeschmuck
Old Man
I'm not sure UDMA_CRC_Errors is something you can RMA, but it's worth a try if that is the path you would like to go down.
Sorry for jumping on you about it, I didn't realize the value hadn't increased since the problem was fixed. I looked at the last two SMART reports and saw the values were significantly different and jumped to a conclusion.
serverboy
You are probably right. The drive is under warranty for 5years so if it does decide to go bang at some point i will just RMA it then. The pool has been healthy all day with no issues so that is a positive.
Ye no worries bud. I'm just new to this stuff so appreciate everyone telling me how to troubleshoot this. The value jumped up quite high from before because every time I kicked off a transfer the messages logs just filled with a ton of those errors so it looks like it was just dropping constantly during every attempt to access the drive.
I have two cold spares in the draw so I should be ok. Im just waiting to move everything off my synology to this system.
joeschmuck
Old Man
Well wait until you are confident the NAS is trouble free.
