Stux
- Jun 2, 2016
On my SRi-F FAN A is the peripheral fan connector. You can tell because if you set the fan mode to heavy IO then the FANA connector spins up to 80% or so. Where as in Standard/Optimal it follows the other headers, ie its CPU temp based.
IIRC FAN1/2 (or was it 0/1) are recommended for CPU fan coolers... and they're near the CPU socket too.
FANA is near the PCI sockets... where you expect it to be used...
