Hi guys,
I ran the warden to iocage script - https://www.ixsystems.com/community...tion-script-some-quick-tips-for-others.68597/ and migrated a warden jail created in 10.3 (VPN, with sabnzbd/cp/sickrage running behind it).
It is set up such that it routes 192.168.0.2/couchpotato or /sickrage or /sabnzbd to the appropriate program.
Now my issue is that I can't get vnet to work in the jail. If I set up IP sharing, going to 192.168.0.2 takes me to the GUI. When I enable vnet, I set up the right IPV4 interface (vnet0:bridge0) with the right IP (192.168.0.2) and default router (192.168.0.1), vnet_default interface (auto) I get the "stopped [jail] due to VNET failure" if I select vnet_default interface to vnet0:bridge0, when I try to save the config I get "Please provide a valid NIC to be used with vnet".
I am not sure what the issue is? Running 11.3-U1.
Thanks in advance!
Thanks in advance!
