network problem
OrelLuzon
Hi
I am working on an intel nuc
All the internet VM works fine
But when I try to ping 8.8.8.8 I can't
I can't see all the apps that are there I keep getting an error message
I updated date and time in bios
Up-to-date date and time everywhere
I would be happy to help please
neofusion
Is that intentional that you set your netmask to /25 and not the much more common /24?
Regarding the time settings, you say you've set it in BIOS but what did you set it to? The time in UTC or something else?
Please also post a screenshot of the network "Global Configuration".
OrelLuzon
Thanks for the comment
I changed now to 24, there was no reason for it
I tried to change the time in the shell
I read a bit and realized that my problem might be the time and date
I am attaching a screenshot of the time I get
I tried to add ntp server right now without success
Patrick M. Hausen
If you get "destination host unreachable" you probably did not set your default router correctly in the global network settings.
neofusion
That's exactly it.
As shown in the last screenshot the default route is the same IP as the IP set on the TrueNAS box. That means TrueNAS has no idea how to get out of the network.
You (OrelLuzon) should set the default gateway to the internal IP of your router. Your router is probably 192.168.1.1 or 192.168.1.254, but please double-check, don't just use my guesses. :smile:
OrelLuzon
That's exactly it.
This was the problem, I changed the default gateway and now it works perfectly
thank you very much :grin:
