Network not detected
pirateghost
Unintelligible Geek
It isn't complicated, you just refuse to learn the nuances.
A plugin is a jail. You can ssh into your FreeNAS and issue:
jls
This will give you a list of your jails that are running
jexec <idOfJail> tcsh
This will put you in the TERMINAL of that jail, just like you were SSH'd into a physical box.
pirateghost
Unintelligible Geek
You're missing out on one of the best aspects of FreeNAS/FreeBSD. The jails....
Ok so, someone can tell me why FreeNAS 10.2 boot and after it show "Generating lalr tables" message? I Googled it and I found no revelant results... Safe or not I want to know why my dedicaded server won't work with FreeNAS. The motherboard is a Supermicro x10sdv-4c-tln2f if it can help. If I can get it work, I will use it for store not important data.
Also by the way, I installed a nightly build. And I add a screenshot of another message I got.
