Network Interface - SMB problem.
zantag
Hi guys.
I try to build my first TrueNas server.
So at first i create lagg with all my four NICs on my server dell710 at load balance mode. But after research on the internet i decide to remove NIC4 from the lagg to use it like physical port with VM>>>DOCKER>>>NGINX PROXY MANAGER for my future nextcloud server.
So i have lagg (NIC1,NIC2,NIC3) at ip 10.10.10.1 and physical NIC4 at ip 10.10.10.3. As i said before i want to use NIC4 only for VM but i was very surprised to know that i cant connect anymore to my SMB via lagg at ip 10.10.10.1 ... SMB now working only on NIC4 at 10.10.10.3.
How to restrict SMB service to use only LAGG port not physical NIC4?
Services | SMB ... click the edit pencil... Bind IP Addresses (under Advanced Options)
zantag
Doesn't work... when i bind the desired IP i cant access SMB shares any more...
ps: I change it with different ip adress and now working ...
