Need to disable gmultipath; SATA disks detected as multipath and reenables itself after reboot
Sysadmin#39
I'm rebuilding my 16-bay NAS with Truenas Core 12.0-U8.1, after running a previous version of Freenas with the same hardware. My issue is that one or more of the disks (all sata, no sas) are improperly detected as multipath disks and show a degraded status. Usually just da0, but sometimes also da1, da2, and da3. I can destroy the multipath/diskX from the CLI (while not in a pool) but it's automatically re-added after a reboot. My concern is that if I need to replace a drive one day, I won't be able to because of the multipath issue. Indeed, I already broke the pool once and wasn't able to detach and replace the disk.
Presently there is no data in the pool so I'll try anything. This is my first post so if I have neglected to include any critical information, please bear with me and help me to find any additional info needed.
Here's my setup:
SuperMicro 15-bay rackmount case
Motherboard: Gigabyte GA-970A-DS3 (rev 1)
CPU: AMD FX-6350
Memory: 16GB
Storage: 16 x 2TB on a RocketRaid 3540 HBA card with a backplane
Here's what I've learned and tried so far (multiple iterations) after referencing dozens of other posts.
- For each iteration, as necessary, I disable SMB, unconfigure Active Directory, destroy all datasets, and destroy the pool, all from the GUI.
- Clear the previous pool info from each drive with 'zpool labelclear daX'. This always results in an 'Operation not permitted' error, so if I set debugflags to 16, it succeeds.
sysctl kern.geom.debugflags=0x10
- list and destroy any detected multipaths
gmultipath list
gmultipath destroy disk1
Rinse and repeat for any other listed mutlipaths, but usually it's only disk1
- Create the pool. I've settled on 2 x 8-disk vdevs in a raid z2 configuration.
zpool create pool raidz2 da0 da1 da2 da3 da4 da5 da6 da7
- 'zpool status' shows the pool is correctly created, with no multipaths listed. However, since I've created the pool in the CLI a reboot is needed before I can import the pool via the GUI to configure further. If you're wondering why I don't create the pool in the GUI in the first place, it's because the gui doesn't show any disks. Well, sometimes it'll show one or two disks. This is another topic for discussion that needs no attention here. For now let's just accept that I can reliably create the pool from the CLI and import it into the GUI upon the next reboot.
zpool status
- Following a reboot and importing the pool into the GUI, da0 (and sometimes also da1-3) are listed as a multipath disk. However, I am able to configure the system further, adding it to Active Directory, configuring datasets, samba, and so on.
I can even expand the pool by adding the other 8 disks, though I didn't necessarily do this on each iteration.
zpool add pool raidz2 da8 da9 da10 da11 da12 da13 da14 da15 zpool status
Everything appears to be working normally save for da0 being improperly listed as a multipath disk.
gmultipath list
If I attempt to destroy the multipath now, the array shows as Degraded, and from here I was not able to remove and reimport the disk to restore the pool to a healthy state. The only thing that works is to destroy and recreate the pool. Obviously this is fine for now but isn't viable once I have data.
zpool status
One post suggested that the multipath data is saved on the disk, much like the zfs pool information, and that it needs to be cleared with dd. I've tried this between destroying and recreating the pool, but there was no change.
dd if=/dev/zero of=/dev/da0 bs=1m count=1 dd if=/dev/zero of=/dev/da0 bs=1m oseek=`diskinfo da0 | awk '{print int($3 / (1024*1024)) - 4;}'`
The gmultipath man page explained that you could load gmultipath at boot time with geom_multipath_load="YES", I figured I could prevent it from loading with geom_multipath_load="NO", which I added to the end of /boot/loader.conf. Again, there was no change, after the next reboot the multipath was listed again.
I've seen posts that suggest using tunables to disable gmultipath but can't find any information that actually explains how to do it. The gmultipath man page lists two variables, kern.geom.multipath.debug and kern.geom.multipath.exclusive, but neither seems appropriate for disabling gmultipath. Reply #2 at
Here are some other posts I've referenced but they did not help my situation.
Unload gmultipath kernel module at startup
Again, this is my first post so please bear with me and provide detailed instructions to help me gather any additional info you may wish to see. Thanks in advance!
Samuel Tai
The supported way to modify loader.conf is by setting Tunables under System->Tunables. In your case, try creating a LOADER-type tunable with variable geom_multipath_load and value NO. Then reboot to make this tunable active.
Sysadmin#39
Thanks for the tip. I've done as you suggested, and then destroyed and recreated the pool, and rebooted to import the pool through the GUI. There is no change. It appears that gmultipath is still loading, as da0 is still showing as a degraded multipath disk (following the first reboot after I recreate the pool). I'm not sure if the value is case sensitive or not, I tried both upper and lowercase. Did I do something wrong?
Samuel Tai
It may not be possible to disable multipath, if it's compiled directly into geom. I'll have to experiment with it a bit to see what's possible.
Samuel Tai
Ok, it appears TruNAS loads geom_multipath by default, regardless of anything in loader.conf. The only other thing to try is to create a Pre-Init script under Tasks->Init/Shutdown Script, to run kldunload geom_multipath. I don't know if this will take effect before your pool is auto-imported after boot.
